6.2.1 pro : repo already exists while syncing
HI,
i’m on pro 6.2.1 beta.
From the seafile client, when i try to upload a folder as a library and sync it, nothing is synced : the library is empty on the serevr.
if I resynchronize and select the same or another folder, i have an error message : “repo already exists”
applet.log
[11/22/17 15:27:02][network detector] got a network failure
[11/22/17 15:27:02][api] network error for http://127.0.0.1:8000/seafmedia/avatars/b/3/9ff683ddb9a8ccbb5d254ecae2423f/resized/80/02a64382874306ec407ae4828baa1f58.png: Connection refused
[11/22/17 15:27:02][network detector] resetting the qt network access manager
[11/22/17 15:27:12]QString::arg: Argument missing: &G?n?rer un lien de t?l?chargement, Seafile
[11/22/17 15:28:36]QString::arg: Argument missing: &G?n?rer un lien de t?l?chargement, Seafile
[11/22/17 15:30:10]Impossible d'ajouter la tâche de téléchargement ?
 Repo already exists
[11/22/17 15:30:22]Impossible d'ajouter la tâche de téléchargement ?
 Repo already exists
[11/22/17 15:30:58]Impossible d'ajouter la tâche de téléchargement ?
 Repo already exists
[11/22/17 15:32:51][network detector] got a network failure
[11/22/17 15:32:51][api] network error for http://127.0.0.1:8000/seafmedia/avatars/b/3/9ff683ddb9a8ccbb5d254ecae2423f/resized/80/02a64382874306ec407ae4828baa1f58.png: Connection refused
[11/22/17 15:32:51][network detector] resetting the qt network access manager
[11/22/17 15:34:52]Impossible d'ajouter la tâche de téléchargement ?
 Repo already exists
[11/22/17 15:35:05]Impossible d'ajouter la tâche de téléchargement ?
 Repo already exists
seafile.log
[11/22/17 15:26:44] seaf-daemon.c(558): starting seafile client 6.1.3
[11/22/17 15:26:44] seaf-daemon.c(560): seafile source code version 5fc440fe04370308d8dd9de4b1c63a388da68278
[11/22/17 15:26:44] ../common/mq-mgr.c(60): [mq client] mq cilent is started
[11/22/17 15:26:44] ../common/mq-mgr.c(106): [mq mgr] publish to heartbeat mq: seafile.heartbeat
[11/22/17 15:26:44] wt-monitor-win32.c(565): GetQueuedCompletionStatus failed, error code 87[11/22/17 15:26:44] wt-monitor-win32.c(565): GetQueuedCompletionStatus failed, error code 87[11/22/17 15:26:44] wt-monitor-win32.c(565): GetQueuedCompletionStatus failed, error code 87[11/22/17 15:26:46] sync-mgr.c(702): Repo '_Projets' sync state transition from 'synchronized' to 'committing'.
[11/22/17 15:27:59] clone-mgr.c(847): Transition clone state for 303fb938 from [init] to [check server].
[11/22/17 15:27:59] [11/22/17 15:27:59] clone-mgr.c(847): Transition clone state for 303fb938 from [check server] to [fetch].
http-tx-mgr.c(4288): Download with HTTP sync protocol version 2.
[11/22/17 15:27:59] http-tx-mgr.c(1132): Transfer repo '303fb938': ('normal', 'init') --> ('normal', 'check')
[11/22/17 15:27:59] http-tx-mgr.c(1132): Transfer repo '303fb938': ('normal', 'check') --> ('normal', 'commit')
[11/22/17 15:27:59] http-tx-mgr.c(1132): Transfer repo '303fb938': ('normal', 'commit') --> ('normal', 'fs')
[11/22/17 15:27:59] http-tx-mgr.c(1132): Transfer repo '303fb938': ('normal', 'fs') --> ('normal', 'data')
[11/22/17 15:27:59] http-tx-mgr.c(1132): Transfer repo '303fb938': ('normal', 'data') --> ('finished', 'finished')
[11/22/17 15:27:59] wt-monitor-win32.c(565): GetQueuedCompletionStatus failed, error code 87[11/22/17 15:27:59] clone-mgr.c(847): Transition clone state for 303fb938 from [fetch] to [done].
[11/22/17 15:30:05] file sync-mgr.c: line 565 (seaf_sync_manager_cancel_sync_task): should not be reached[11/22/17 15:36:03] sync-mgr.c(832): Failed to start http upload: Empty argument(s)
[11/22/17 15:36:03] sync-mgr.c(764): Repo '_Projets' sync state transition from committing to 'error': 'Failed to start upload.'.
[11/22/17 15:36:03] sync-mgr.c(702): Repo '_Info' sync state transition from 'synchronized' to 'committing'.
Any idea ?
Regards
Ok,
I selected a subfolder with the same name which was empty.
/_Charte/_Charte
Now after restarting the client i can syn to the folder /_Charte.
The syncing process is ok.
But there may be confusion about folder paths in seafile client, as you may know…
Regards
