Hello all, i need help i have update my seafile for 6.3.4 but when i want to restart my seahub.sh i have this error
./seahub.sh restart.fastcgi
stopping seahub…
LC_ALL is not set in ENV, set to en_us.UTF.8
Starting seahub (fastcgi) at 127.0.0.1:8000
Warning: File comment has changed since version 6.3, while table base_filecomment is not migrated yet, please consider migrate it according to v6.3.0 release note, otherwise the file comment feature will not work correctly
unknow command: ‘runfcgi’
type ‘manage.py help’ for usage
Error:Seahub failed to start.
./manage.py
File “./seahub.manage.py”, line 8, in
from django.core.managmenet import execute_from_command_line
ImportError: No module named django.core.management
i’m trying to access with HTTPS but i have all time this error
From 6.2, It is recommended to use WSGI mode for communication between Seahub and Nginx/Apache. Two steps are needed if you’d like to switch to WSGI mode:
Change the config file of Nginx/Apache.
Restart Seahub with ./seahub.sh start instead of ./seahub.sh start-fastcgi
The configuration of Nginx is as following:
