I’m trying to enable search, but it doesn’t seem to work.
I’m on seafile-pro-server-9.0.13 and on Arch Linux.
sudo docker pull elasticsearch:7.16.2
sudo mkdir -p /opt/seafile-elasticsearch/data
sudo chmod -R 777 /opt/seafile-elasticsearch/data/
sudo docker run -d \
--name es \
-p 9200:9200 \
-e "discovery.type=single-node" -e "bootstrap.memory_lock=true" \
-e "ES_JAVA_OPTS=-Xms1g -Xmx1g" -e "xpack.security.enabled=false" \
--restart=always \
-v /opt/seafile-elasticsearch/data:/usr/share/elasticsearch/data \
-d elasticsearch:7.16.2
vi conf/seafevents.conf
[INDEX FILES]
external_es_server = true
es_host = es
es_port = 9200
interval = 10m
highlight = fvh
index_office_pdf = true
sudo systemctl restart seafile.service
sudo systemctl restart seahub.service
sudo docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
756a78dbb137 elasticsearch:7.16.2 "/bin/tini -- /usr/l…" About an hour ago Up 19 minutes 0.0.0.0:9200->9200/tcp, :::9200->9200/tcp, 9300/tcp es
cat seafevents.log
[2022-12-22 15:26:50,479] [INFO] work weixin notice sender is disabled
[2022-12-22 15:26:50,479] [INFO] search indexer is disabled
[2022-12-22 15:26:50,479] [INFO] seahub email sender is started, interval = 1800 sec
