So I’ve enabled google as my auth provider. I also have LDAP enabled that contains all of the emails that should be allowed to SSO in.
Can I disable the user/pass prompting and force everyone to use SSO now?
I would like the same thing.
Once SSO is live, then disable login and auto SSO redirect.
Dirty hack doing auto redirect:
In file /seafile-server-latest/seahub/seahub/templates/registration/login.html
find:
$(function() {
$(‘#sso’).on(‘click’, function() {
window.location = “{% url ‘sso’ %}{% if next %}?next={{ next|escape }}{% endif %}” + encodeURIComponent(document.location.hash);
return false;
Replace with:
(function () {
return false;
This is a quick and dirty hack and will most likely not survive an update… use at your own risk
Thanks, I decided I was having to do too many things like this and moved away from Seafile a few months ago. I didn’t want to be dealing with breakage all the time, just pull a new docker container and restart. Too many other things I wanted to work on
Just wanted to see if this is possible with v11?
We enabled sso and would really like to disable the regular login to only allow sso.
Thanks.
I use NGINX as reverse proxy and I was able to disable password login by redirecting the login page to SSO login.
Here is the redirect code:
location ~ ^(/accounts/login)(.*)$ {
return 301 /oauth/login$2;
Similar redirection can be achieved using any other reverse proxy.
