After login I get "Page unavailable"
Hello folks,
I’m running Seafile Pro as container in a rootless podman environment using NGINX as a reverse proxy. A HTTP response should take this route:
Client <–> NGINX Port 443 <–> proxy_pass http://127.0.0.1:8002;
Port 8002 is mapped to Port 80 of the seafile container (127.0.0.1:8002->80/tcp). I can access the login page at https://seafile.example.com. My browser’s address bar shows https://seafile.my-it-brain.de/accounts/login/?next=/. After loging in as Seafile-Admin I get the error:
Page unavailable
My NIGNX configuration looks as follows:
    # Listen on Port 443
    listen 443 ssl http2;
    listen [::]:443 ssl http2;
    server_name seafile.example.com;
    add_header Strict-Transport-Security max-age=31536000;
    ssl_certificate …fullchain.cer;
    ssl_certificate_key …seafile.example.com.key;
    ssl_protocols TLSv1.2 TLSv1.3;
    ssl_ciphers '…';
    ssl_prefer_server_ciphers on;
    ssl_dhparam /etc/nginx/dh_params.pem;
    # Path to the root of your installation
    root …/public;
	location ^~ /.well-known/acme-challenge/ {
	default_type "text/plain";
	root …/public;
	location = /.well-known/acme-challenge/ {
	return 404;
	proxy_read_timeout 310s;
	proxy_set_header Host $host;
	proxy_http_version 1.1;
The NGINX access log of my host shows the following entries for each login attempt:
203.0.113.9 - "GET / HTTP/2.0" 302 0 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/110.0"
203.0.113.9 - "GET /accounts/login/?next=/ HTTP/2.0" 200 4000 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/110.0"
203.0.113.9 - "POST /accounts/login/?next=/ HTTP/2.0" 500 285 "https://seafile.my-it-brain.de/accounts/login/?next=/" "Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/110.0"
The logs of the seafile container show no error:
** Message: 11:48:51.432: seafile-controller.c(1023): loading seafdav config from /opt/seafile/conf/seafdav.conf
Seafile server started
Done.
Successfully created seafile admin
Seahub is started
Done.
I appreciate any assistance on solving this issue. Could someone help, please?
I tried to access the seafile contianer instance directly without using the reverse proxy by accessing http://seafile.example.com:8002 but I got the same error. Therefore the reverse proxy is not the root case for this issue.
Still have know clue what’s bothering the service or which logs to search.
I was able to resolve the issue by using the Playbook Debugger. The root cause was a that I was using the wrong variable in some task.
