running Ubuntu 14.04.5 LTS with mysql
after following the upgrade instructions the server started. When trying to login over the webinterface an error message appears:
Page unavailable
(http://192.168.178.xxx:8000/accounts/login/?next=/)
Seafile client 4.3.3 says trying to login “internal servererror”
I cleared the server cache in /tmp/seahub_cache
seahub.log is only showing old entries from 2017
last seafile log entries are:
[08/12/18 13:59:38] http-server.c(161): fileserver: worker_threads = 10
[08/12/18 13:59:38] http-server.c(176): fileserver: fixed_block_size = 8388608
[08/12/18 13:59:38] http-server.c(191): fileserver: web_token_expire_time = 3600
[08/12/18 13:59:38] http-server.c(206): fileserver: max_indexing_threads = 1
[08/12/2018 01:59:38 PM] ../common/mq-mgr.c(54): [mq client] mq cilent is started
[08/12/2018 01:59:39 PM] size-sched.c(96): Repo size compute queue size is 0
[08/12/2018 02:04:17 PM] Disconnected from daemon
[08/12/18 14:04:59] http-server.c(161): fileserver: worker_threads = 10
[08/12/18 14:04:59] http-server.c(176): fileserver: fixed_block_size = 8388608
[08/12/18 14:04:59] http-server.c(191): fileserver: web_token_expire_time = 3600
[08/12/18 14:04:59] http-server.c(206): fileserver: max_indexing_threads = 1
[08/12/2018 02:05:00 PM] ../common/mq-mgr.c(54): [mq client] mq cilent is started
[08/12/2018 02:05:01 PM] size-sched.c(96): Repo size compute queue size is 0
[08/12/2018 02:10:01 PM] size-sched.c(96): Repo size compute queue size is 0
[08/12/2018 02:15:01 PM] size-sched.c(96): Repo size compute queue size is 0
[08/12/2018 02:20:01 PM] size-sched.c(96): Repo size compute queue size is 0
maybe one can find hints in seahub_django_request.log:
2018-08-12 12:17:02,792 [ERROR] django.request:256 handle_uncaught_exception Internal Server Error: /accounts/login/
File "/opt/seafile/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/core/handlers/base.py", line 132, in get_response
File "/opt/seafile/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/utils/decorators.py", line 110, in _wrapped_view
response = view_func(request, *args, **kwargs)
File "/opt/seafile/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/views/decorators/cache.py", line 57, in _wrapped_view_func
File "/opt/seafile/seafile-server-6.2.5/seahub/seahub/auth/views.py", line 113, in login
if form.is_valid():
File "/opt/seafile/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/forms/forms.py", line 184, in is_valid
return self.is_bound and not self.errors
File "/opt/seafile/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/forms/forms.py", line 176, in errors
self.full_clean()
File "/opt/seafile/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/forms/forms.py", line 393, in full_clean
self._clean_form()
File "/opt/seafile/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/forms/forms.py", line 417, in _clean_form
cleaned_data = self.clean()
File "/opt/seafile/seafile-server-6.2.5/seahub/seahub/auth/forms.py", line 66, in clean
username = self.get_username_by_login(login)
File "/opt/seafile/seafile-server-6.2.5/seahub/seahub/auth/forms.py", line 46, in get_username_by_login
username = Profile.objects.get_username_by_login_id(login)
File "/opt/seafile/seafile-server-6.2.5/seahub/seahub/profile/models.py", line 93, in get_username_by_login_id
return super(ProfileManager, self).get(login_id=login_id).user
File "/opt/seafile/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/db/models/manager.py", line 127, in manager_method
return getattr(self.get_queryset(), name)(*args, **kwargs)
File "/opt/seafile/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/db/models/query.py", line 328, in get
num = len(clone)
File "/opt/seafile/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/db/models/query.py", line 144, in __len__
self._fetch_all()
File "/opt/seafile/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/db/models/query.py", line 965, in _fetch_all
self._result_cache = list(self.iterator())
File "/opt/seafile/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/db/models/query.py", line 238, in iterator
results = compiler.execute_sql()
File "/opt/seafile/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/db/models/sql/compiler.py", line 840, in execute_sql
cursor.execute(sql, params)
File "/opt/seafile/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/db/backends/utils.py", line 64, in execute
File "/opt/seafile/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/db/utils.py", line 98, in __exit__
File "/opt/seafile/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/db/backends/mysql/base.py", line 124, in execute
File "/usr/lib/python2.7/dist-packages/MySQLdb/cursors.py", line 174, in execute
File "/usr/lib/python2.7/dist-packages/MySQLdb/connections.py", line 36, in defaulterrorhandler
raise errorclass, errorvalue
OperationalError: (1054, "Unknown column 'profile_profile.list_in_address_book' in 'field list'")
can anyone help please?
Greetings, Jinx.
