Any way to backup/export wiki in Seafile 12?
The new wiki module is great in Seafile 12. However, I cannot find any way to backup/export wiki or sync wiki to local. Since wiki is based on sdoc, is it possible to get the raw sdoc files of the wiki?
Currently the wiki is a Seafile library with a special folder structure. The library is hidden from the web interface and the desktop clients. So it cannot be synced. On the other hand, if the wiki library be synced to local, a user may accidentally damage the internal folder structure.
Why do you need to backup a single wiki instead of backup the whole Seafile server?
Same concern here. I’m wondering since sdoc files can be converted to Doc or Markdown formats, is it possible to do the same with the wiki?
It will be in version 13.0.
