Athorization failed after Seafile Upgrade
Recently I upgraded community Seafile server from version 4.1.2 to 6.0.3.
All upgrade process gone without issues.
After all I successfully open web interface but can’t login.
Every time I got message: “Incorrect email or password” when try to authorize.
Even when I reset admin login via reset-admin script new credentials got same message: “Incorrect email or password”
Also I couldn’t find something suspicious in seafile_django and saefile.log
Any help appreciated!
Have you customized the login page?
Yes. There is customized login page.
Delete the old customization file and re-do the customization based on the newest file will solve your problem.
You was right, thank you!
Disabling of customized page worked.
Can I then redeploy it by manual at http://manual.seafile.com/config/seahub_customization.html ?
