I’m running my seafile server in a vdhx on Hyper-V.
What’s the best possible way to backup the vhdx file?
I don’t want to copy the hole vhdx all the time etc.
Use Veeam, it is free for hyper-v if simple backups. Also stuff like Acronis may be ok for you.
Thanks that sounds good, I’ll take a look at Veeam’s free edition.
I did find an other solution, altaro it’s free for two VM’s then you need to pay if you want more.
And for me that only uses one VM it’s perfect
Veeams free software was so limited that I don’t find any use for it other then manually backups.
With Altaro I can use the hole software etc.
