Hello, I’ve been having this problem where Seafile seems to be limited to 12MBps when downloading or uploading files through the Seahub frontend, even in my local network (using the local ip of the server in the browser). When using SeaDrive the download/upload will use more like 70MBps which is much faster. I don’t know if this could be an nginx problem or maybe Seahub is just slower?
I am using Seafile 9.0 installed through the install script recommended in documentation.
Server Config:
- i5 11400F
- 32GB ram
- HDD disk for seafile data
seafdav.conf
[WEBDAV]
enabled = true
port = 8080
share_name = /seafdav
ccnet.conf
[General]
[Database]
ENGINE = mysql
HOST = 127.0.0.1
PORT = 3306
USER = seafile
PASSWD = $password
DB = ccnet_db
CONNECTION_CHARSET = utf8
seafile.conf
[history]
keep_days = 7
[library_trash]
expire_days = 14
[fileserver]
port = 8082
web_token_expire_time = 10800
http_temp_file_ttl = 86400
http_temp_scan_interval = 3600
max_download_dir_size = 10240
max_sync_file_count = -1
fs_id_list_request_timeout = -1
[database]
type = mysql
host = 127.0.0.1
port = 3306
user = seafile
password = $password
db_name = seafile_db
connection_charset = utf8
seafile.nginx.conf
listen 80;
listen 443 ssl;
ssl_certificate /etc/letsencrypt/live/$file1;
ssl_certificate_key /etc/letsencrypt/live/$file2;
server_name $servername;
proxy_set_header Host $host;
proxy_read_timeout 1200s;
proxy_request_buffering off;
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
location /seafdav {
proxy_pass http://127.0.0.1:8080/seafdav;
access_log /var/log/nginx/seafdav.access.log seafileformat;
nginx.conf
user www-data;
worker_processes auto;
pid /run/nginx.pid;
include /etc/nginx/modules-enabled/*.conf;
events {
worker_connections 768;
#multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
types_hash_max_size 2048;
# server_tokens off;
# server_names_hash_bucket_size 64;
# server_name_in_redirect off;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
access_log /var/log/nginx/access.log;
error_log /var/log/nginx/error.log;
# Gzip Settings
gzip on;
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# gzip_types text/plain text/css application/json application/javascript text/xml application/xml application/xml+rss text/javascript;
# Virtual Host Configs
include /etc/nginx/conf.d/*.conf;
include /etc/nginx/sites-enabled/*;
#mail {
# # See sample authentication script at:
# # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
# proxy on;
# server {
# listen localhost:143;
# protocol imap;
# proxy on;
