Hi dudes,
I’m using seafile for several years with an online root server. So far, so good. But now I want to use seafile in a local lan installation. My goal is to accessing the server within my openvpn connection. The openvpn part is working fine for a long time, so thats not the topic here. I just want to reach the seafile web gui over the local lan, without a domain name and without ssl and so on, because I dont need this.
I’ve installed seafile inside a vm (proxmox) with mysql (mariadb-server) and nginx as root. The server is reachable within my local lan and I’m administrating via ssh.
I tried the process without nginx but just using the gunicorn and this works fine. But if I try to using nginx, the weg gui get screwed up. I will attach a screenshot in here. I’m able to login, but after this I just see a blank screen. Deleting the cache did not help.
Here are a few snippets of my configs:
/etc/nginx/sites-available/default
listen 80;
server_name 10.23.23.25;
proxy_set_header Host $host;
proxy_read_timeout 1200s;
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
proxy_send_timeout 36000s;
root /root/seafile/seafile-server-latest/seahub;
/root/seafile/conf/ccnet.conf
[General]
USER_NAME = seafile-proxmox
ID = asdfsadfsdafsdafsadfsadfsadfasdfsdafasdf
SERVICE_URL = http://10.23.23.25
[Client]
PORT = 13419
[Database]
ENGINE = mysql
HOST = 127.0.0.1
PORT = 3306
USER = seafile
PASSWD = pw
DB = ccnet-db
CONNECTION_CHARSET = utf8
/root/seafile/conf/
# -*- coding: utf-8 -*-
SECRET_KEY = "asdfkjasdkfjasdkfjasdlfkjasldfkjalsdkfj"
FILE_SERVER_ROOT = 'http://10.23.23.25/seafhttp'
DATABASES = {
'default': {
'NAME': 'seahub-db',
'USER': 'seafile',
'PASSWORD': 'pw,
'HOST': '127.0.0.1',
'PORT': '3306'
My first attempt was with a local domain name (with the DNS resolver inside of my pfsense) but with the same results. So at first I want to reach the seafile webinterface with just a ip. To be clear: after the nginx installation, I tried it with “http:10.23.23.25” and here you see my results.
I’m thankful for any advise!
Greetings
oneiro
Edit: The image-upload in here was not possible, so here is a link (why???):
Edit 2: I’m even not allowed to add a link, so here a new try… delete the blanks…
https:// postimg.cc/ grG35g5T
