Can't find seahub_settings.py
Hello
I installed seafile on a pi raspberry with raspbian jessie.
I wanted to set up sending email but could not find the file seahub_settings.py. I installed it several times but can not get this file.
I use the latest version of seafile that I install with sqlite3. Have you also encountered this problem?
Which version of seafile server did you install? The location of the files changed some time ago
https://manual.seafile.com/deploy/new_directory_layout_5_0_0.html
Greetings Jack
