I have tried but I can’t get seafdav to work, I have looked in the manual but I can’t find any solution.
I have opend port 8080 in my firewall and also in my router but no luck.
[WEBDAV]
enabled = true
port = 8080
fastcgi = true
share_name = /seafdav
NGINX file:
listen 80;
server_name xxxx;
server_tokens off;
listen 443;
ssl on;
ssl_certificate /etc/nginx/ssl/seafile.crt; # path to your cacert.pem
ssl_certificate_key /etc/nginx/ssl/seafile.key; # path to your privkey.pem
server_name xxxx;
server_tokens off;
fastcgi_pass 127.0.0.1:8000;
fastcgi_param HTTPS on;
fastcgi_read_timeout 36000;
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
proxy_send_timeout 36000s;
proxy_request_buffering off;
location /seafdav {
fastcgi_pass 127.0.0.1:8080;
root xxxxx;
