Hi, When I try to install Seadrive under macOS Ventura, I get a message after starting Seadrive (see screenshot - in German) which says (translated into English) “You must manually add the SeaDrive kernel extension to the system settings. Click OK to open System Preferences. After that, please restart SeaDrive.”
Well … I looked around at the system settings but I found nothing which looked like where I can do that.
Is there any ‘a little bit more detailed’ instruction what to be done?
Thanks.
m
