I created a Kubuntu 18.04 VM and installed seafile docker container.
I am connected to my FreeNAS server via a 10 gig card
I am sharing via SMB
The share is mounted using fstab to /media/user/smbshare
How can i use my FreeNAS smb share to store the data of my seafile docker container?
Thanks in Advance
iirc you should be able to mount that smb share on the host OS, and then mount that directory as a volume
Can you please post the container’s logs?
Thank you for your response.
Where can i find the logs and which one would you like
In docker you have to use the docker logs
command. For work like the tail
command you can add -f (like tail -f)
and --tails x (like tail -nx)
Edit: Example: docker logs --tails 10 container_name
