Connection refused, clean installation Raspbian buster
In a fresh installation on a Rasberry Pi4, raspbian buster, sql lite and default web server you get “connection refused” when trying to connect trought the web
The solution is edit conf/gunicorn.conf and change bind = “127.0.0.1:8000” with bind = “0.0.0.0:8000”
Obviously is a bug
Obviously, the whole world is a bug… :joy:
I had the same experience at upgrades from 6.3.4 to 7.0.4 at Ubuntu and ARM (Rock64). The solution as described above.
Yup, if you search in the forum, you will understand why. Its not a bug its a feature :wink:
