On seadrive 0.9.1 (windows), i noticed that the context (explorer) menu is only available on files, but not at the folder level.
I think that is should be also available on the folder level.
As based on the menu displayed on a file
- Download – Should be removed (the file is already available)
- Get seafile Download Link – should be available also on a folder
- Get seafile Internal Link – should be removed (or also available on a folder)
- Lock this file – should be available also on a folder (all files are locked)
- View file history – should be available also on a folder
Also, how can we translate these options ?
regards
