Copied entire ../seafile to a new directory and ./seahub.sh won't launch
seahub
#1
Hi all
I’ve been happily running my own seafile server since 2016 and recently I’ve moved (using mv) my seafile directory from /home/seafile to /opt/seafile. I did this in preparation for upgrading to 7.0. I have modified my …/seafile/ccnet/seafile.ini directory to mirror the changed location. I’ve also updated my nginx config file for this change. ./seafile.sh starts no problems. Is there any other config files i need to update?
I’m not seeing any particular errors in the seahub.log, i’m only getting an info message about seafevents.db. What i get in the command line is as follow:
LANG is not set in ENV, set to en_US.UTF-8
./seahub.sh: line 231: warning: setlocale: LC_ALL: cannot change locale (en_US.UTF-8)
Error:Seahub failed to start.
My current version is seafile server pro 6.3.9 running on Debian 9.9.
Any Help would be hugely appreciated :slight_smile:
#2
File system rights sat correctly? You could add DEBUG=true to your seahub_settings.py to get more information.
#3
Yep, i believe, so It was set as 755, but i’ve tried again at 777 with no changes. With root as owner. I’ve tried setting the debug flag in seahub_settings.py as per your suggestions but to no avail. Nothing has been written seahub.log file since this problem began. Looking through the other logs, there is some errors in seafile.log & in controller.log but they were occurring long before i had this issue problem anyway. Any other suggestions?
Thanks
#4
After having anther closer look at my seahub-settings.py i realized in my fault finding i introduced a typo.
Now that’s resolved, i’m able to start seahub but i’m getting several errors in my seahub.log, all along the same line of this.
[ERROR] django.request:135 handle_uncaught_exception Internal Server Error
I can attach the complete section of log that is output when starting seahub, but its mostly similar to the above and says
OperationalError: no such table: api2_tokenv2
OR
OperationalError: no such table: notifications_notification
The other thing i changed which i believe got seahub working again was changing the pids_dir under gunicorn.conf
pids_dir = ‘/home/seafile/pids’
TO
pids_dir = ‘/opt/seafile/pids’
I’ve also read this might be related to my memcached settings in seahub_settings.py, however i’ve had memcached commented out of this file for a while now, before the problems began, however i have got memcached installed.
Would this be related to my issues?
Thanks very much.
Seafile 6.3.4 /Apache/Centos : ERROR django.request:135 handle_uncaught_exception Internal Server Error: /avatar/add/
#5
Try to update, even though there isn’t any avaiable. Hopefully, this will fix it.
#6
i did run an update from 6.3.9 to 6.3.14 (following the normal procedure and running the minor upgrade script) and unfortunately no change. I Could try running one of the other upgrade scripts?
