Copying user libraries between two Seafile instances
Is there a tool (not the Seafile client) that allows to copy a user library between two seafile instances?
BR,
Krzysztof Wadówka
PSNC
I found such a solution:
seaf-fsck.sh --export
seaf-import.sh
Br,
KW.
it would be even better if it was possible to keep several instances in sync (federation). like a RAID over network.
https://manual.seafile.com/deploy_pro/deploy_in_a_cluster.html
Federation is not equal cluster setup. This needs to be added to Seafile.
I know what is federation. But he after this saying something like RAID. Federation is not good practice, cause it have still dependency on running root server. Cluster can be setup as RAID where is no root server, only synchronization between nodes.
