Hi. I’m running OnlyOffice in Seafile Professional 8.0.10 and everything works fine. But I noticed that e.g. only docx was added to the ONLYOFFICE_EDIT_FILE_EXTENSION config item as default and not doc, so I added also ‘doc’ and now I can edit also doc files. However, I also added ‘csv’ which is supported by OnlyOffice, but when I click on a csv file, it just opens in the Seafile viewer and not in OnlyOffice. Since doc files work after I added it, I know the config file is correct.
Here is the relevant part from my seahub_settings.py:
ONLYOFFICE_FILE_EXTENSION = (‘doc’, ‘docx’, ‘ppt’, ‘pptx’, ‘xls’, ‘xlsx’, ‘odt’, ‘fodt’, ‘odp’, ‘fodp’, ‘ods’, ‘fods’, ‘csv’)
ONLYOFFICE_EDIT_FILE_EXTENSION = (‘doc’, ‘docx’, ‘ppt’, ‘pptx’, ‘xls’, ‘xlsx’, ‘odt’, ‘odp’, ‘ods’, ‘csv’)
Any ideas?
Thanks!
