Hi all,
I am running Seafile CE 7.1.5 through docker-compose (based on the docker-compose.yml
referred in the documentation).
I was trying to customize the web UI via a custom CSS file, initially based on the focmb/seafile_custom_css_green example on Github (also referred in the documentation), then I tried using @u-alexey’s custom-light-dark-theme-for-7-1-3-ce
topic from this forum.
The issue I’m facing is that whenever I specify the custom CSS via seahub_settings.py
's BRANDING_CSS
setting the various UI buttons (e.g., New Library, Share, etc.) stop working completely. As in nothing happens when I click them, including no errors in the Javascript console, just plain nothing.
(Other options, such as LOGO_PATH
and FAVICON_PATH
work fine, also the CSS specified in this way is correctly fetched by the browser as part of the page load process.)
Then I tried applying the CSS via the admin settings (ENABLE_CUSTOM_CSS
checked and the actual CSS in the CUSTOM_CSS
field) and this works.
I would prefer if it were possible to have this applied via the seahub_settings.py
file though.
So, does anyone have any idea why this might not be working?
Thanks!
Best regards
(Sorry, I can’t include links in posts, hence the vague explanations of my sources.)
