i have accidentally deleted my seafile app folder, but i have still the data folder. Is it possible to recover the data or not?
Thanks
Thanks
There is a trash bin in each library. If you haven’t cleaned it, you should be able to find the deleted files there.
Hi, I may misunderstand what you mean in the last reply.
This is probably what you are looking for: https://forum.seafile.de/t/solved-recover-data-without-database/4373
Thanks,
My fault The database file is located in the data folder!
Seems the link is broken?
