Data volume/transferred shows 0
in my user profile i can see "Datenvolumen in diesem Monat: " (data volume/transferred in this month). it shows 0 bytes. where can i configure it to show the acutal transferred bytes in month? also the statistics page in system settings shows nothing.
markus
Hi together, Hi Markus,
Do you have a solution for this error? Data volume this month it shows 0 bytes.
Because i have the same issue.
I am testing seafile server pro version 6.04 on CentOs7.
Where can i set this up?
Thanks in advance.
Sefan
afaik this number only shows the amount of traffic generated through links (shared library/file/folder and the amount of data downloaded, not sure if it includes upload)
It works great. Thanks a lot.
Stefan
