Deploy behind Apache?
I set up a personal Seafile server running on a Windows box using this guide: https://manual.seafile.com/deploy_windows/download_and_setup_seafile_windows_server.html
I’ve had it limited to my internal network only but now wish to access it remotely. I found this guide: https://manual.seafile.com/deploy/deploy_seafile_behind_nat.html
One of the things mentioned is “If you do not deployed Seafile behind Apache/Nginx you need to configure port forward for all the components listed below. (not recomended!)”
Following the Windows guide there was no mention of Apache. Do I have to start all over or is it possible to move my existing Seafile Server instance behind Apache? The files I have in there don’t contain anything super personal like banking info, but still I would like to keep them secure. If it’s not easy to migrate without starting over, is it a big deal to not use Apache?
Thanks!
If you use the client with encrypted libaries, there will be a E2E encryption. I think Apache as reverse proxy on Windows could be possible, the config of apache should be the same, but I don’t know that the Windows Server can handle a reverse proxy.
I run Seafile on a dedicated server behind an apache proxy.
I published some notes how I had to configure the proxy and which Seafile settings I had to change:
http://www.kobelnet.ch/Blog/2016/10/10/Seafile_behind_a_proxy
Thank you both for the input. I’ll do some reading and see what I can do.
Interesting article. I’ve had “setting up SSL” for a long time in my to do list, and this seems to be quite a straight-forward solution. In my case as I am running Seafile on UbuntuServer, I’m thinking of setting up an instance of Apache publicly accepting connections and then forwarding HTTP on a locally open port of Seafile, not to expose Seafile externally.
