I don’t get how it happens, so here is a quick description :
User alerts me because SeaDrive and Seafile don’t show the same content of a folder.
- SeaDrive show much more files than web interface.
- Files that appears in Explorer but not on Seafile web can’t be open via Explorer.
- Files creates by the user are available.
The first thing I’ve done, without thinking, was disconnect/reconnect seadrive to force re-indexing. No result, always different content in Explorer and Seafile web interface.
Then I check the version of SeaDrive, 2.0.21, so I update to 2.23. No effects.
Then, I disconnected/reconnected seadrive 2.0.23 to force re-indexing. Still no effects.
Finaly I decided to remove the account, quit SeaDrive, remove seadrive_root folder, reboot, and reconnect the user account. Nice, problem solve for the user.
After searching in the library’s history, I have seen that the faulty folder was moved, the user didn’t know that as the whole old directory was still present on his explorer. He continued to work on the old path as usual.
SeaDrive should have updated the faulty directory listing when I disconnected/reconnected the account.
What happens that create this situation ?
I’ve got SeaDrive logs and screenshots to help investigation.
