Disk Usage Not Showing Correctly
I have Seafile Pro 11.0.16 deployed in docker and it works great but when I see the storage details, it says “Used: 4.2 KB / --”. When I run df on the directory that is mounted to the container, it shows the total value of the disk there, as well as from inside the container as well (details below).
This is my docker-compose.yaml:
  db:
    image: mariadb:10.11
    container_name: seafile-mysql
      - MYSQL_ROOT_PASSWORD=${MYSQL_ROOT_PASSWORD}  # Required, set the root's password of MySQL service.
      - MYSQL_LOG_CONSOLE=true
      - MARIADB_AUTO_UPGRADE=1
      - ./config/seafile-mysql/db:/var/lib/mysql  # Required, specifies the path to MySQL data persistent store.
    networks:
      - seafile-net
  memcached:
    image: memcached:1.6.18
    entrypoint: memcached -m 256
    networks:
      - seafile-net
  elasticsearch:
    image: elasticsearch:8.13.0
      - discovery.type=single-node
      - bootstrap.memory_lock=true
      - "ES_JAVA_OPTS=-Xms2g -Xmx2g"
      - "xpack.security.enabled=false"
    ulimits:
      memlock:
        soft: -1
        hard: -1
    mem_limit: 4g
      - ./config/seafile-elasticsearch/data:/usr/share/elasticsearch/data  # Required, specifies the path to Elasticsearch data persistent store.
    networks:
      - seafile-net
  seafile:
    image: docker.seadrive.org/seafileltd/seafile-pro-mc:11.0-latest
      - "10080:80"
      # - "10443:443"  # If https is enabled, cancel the comment.
      - ./config/seafile-data:/shared  # Required, specifies the path to Seafile data persistent store.
      - DB_HOST=db
      - DB_ROOT_PASSWD=${DB_ROOT_PASSWD}  # Required, the value should be root's password of MySQL service.
      - TIME_ZONE=${TIME_ZONE}
      - SEAFILE_ADMIN_EMAIL=${SEAFILE_ADMIN_EMAIL}
      - SEAFILE_ADMIN_PASSWORD=${SEAFILE_ADMIN_PASSWORD}
      - SEAFILE_SERVER_LETSENCRYPT=${SEAFILE_SERVER_LETSENCRYPT}  # Whether to use https or not
      - SEAFILE_SERVER_HOSTNAME=${SEAFILE_SERVER_HOSTNAME}  # Specifies your host name if https is enabled
    depends_on:
      - db
      - memcached
      - elasticsearch
    networks:
      - seafile-net
networks:
  seafile-net:
and this is the outputs of the df commands:
[Nov25 12:47 AM] 30 juke@jukemini2:[seafile-pro]$ df -h ./config/seafile-data/
Filesystem      Size  Used Avail Use% Mounted on
/dev/nvme0n1p2  457G   19G  415G   5% /
[Nov25 12:47 AM] 31 juke@jukemini2:[seafile-pro]$ docker exec -it seafile /bin/bash
root@a29392e42163:/opt/seafile# df -h /shared
/dev/nvme0n1p2  457G   19G  415G   5% /shared
Any help or suggestions would be greatly appreciated!
I encountered the same issue with the storage details showing "Used: 4.2 KB / --". From my understanding, the "--" likely indicates that the storage is unlimited until the server’s disk is full. However, I agree that it would be helpful to see the total capacity displayed.
Given that Seafile is designed for multiple users with quotas, it seems logical that without a quota being manually assigned by an admin or set as a default in seafile.com, it would display “–”. This way, the system doesn’t assume a limit where none has been explicitly defined.
If you’re managing multiple users, you might want to consider setting quotas to better manage storage and see more detailed usage information.
I use seafile just for myself so it isn’t too big of a deal but hmm…
Like me, so:
You should add this to your seafile.conf:
[quota]
# default user quota in GB, integer only
default = 2
Note that the “-” you’re seeing indicates the user quota and is not meant to show total disk space.
https://manual.seafile.com/latest/config/seafile-conf/
