why is the docker image the last version that is available? Current version of pro is 7.1.7 on docker from 9/1/2020.
You describe as method 1 use docker, but why are the images months behind the current pro version 7.1.8 from 10/12/2020.
Why do you not just build it if when you build all other versions?
