I´m running the official Docker Server and I messed up, but don´t understand why?
I did some testing doing backup of the shared folder, and after changing user and group from root to “myuser” and then nothing works, even if I´m reverting to root again (this includes all sub folders).
Anyone that could explain why this is a problem?
What are the seafile docker username, not root?
can you post your docker logs? docker logs container_id
On my test machine the shared folder is owned by the user root with permissions 755. Except for the subfolder db this belongs to the user syslog and the group systemd-resolve
Ok, I did a new install and there was a number of different owners and groups in sub folders, so I guess this was the problem(?)
I will not try to fix this, I just migrated data to new instance.
