Well,
i thought i’D give it a try, and followed the documentation.
But whatever i try: i can’t access https::mydomain.com/onlyoffice/welcome.
I will, indeed, have a Documentserver running on http://ipadress:88/welcome, like here:
So it is working somehow, but not for Seafile, because, when i open an office doc, page will go blank.
When i look into the source of the blank page it gives back the link to api,js.
Thats it.
My seafile.conf for nginx:
# Required for OnlyOffice DocumentServer
“” $scheme;
“” $host;
default upgrade;
“” close;
# onlyofficeds
location /onlyofficeds/ {
# IMPORTANT ! - Trailing slash !
proxy_http_version 1.1;
proxy_read_timeout 3600s;
proxy_connect_timeout 3600s;
# IMPORTANT ! - Subfolder and NO trailing slash !
My seahub settings.py:
Enable Only Office
ENABLE_ONLYOFFICE = True
VERIFY_ONLYOFFICE_CERTIFICATE = True
ONLYOFFICE_APIJS_URL = ‘https://mydomain/onlyofficeds/web-apps/apps/api/documents/api.js’
ONLYOFFICE_FILE_EXTENSION = (‘doc’, ‘docx’, ‘ppt’, ‘pptx’, ‘xls’, ‘xlsx’, ‘odt’, ‘fodt’, ‘odp’, ‘fodp’, ‘ods’, ‘fods’)
ONLYOFFICE_EDIT_FILE_EXTENSION = (‘docx’, ‘pptx’, ‘xlsx’)
But no avail.
After changing the conf file for nginx, i thought i should have to restart the nginx process, but now it fails. It claims: that there might be to ‘’ servers…
So what next? Read hrs over hrs, but can’t get it.
Thanks for help
jM
