Downloaded latest seadrive client version 0.7.0 on W10 machine.
The issue that I’m having is that when I have gmail open in browser and drag drop attachment it crashes the client. I checked multiple browsers and they all do the same thing.
Tried two different machines and same thing is happening.
It was working on 6.2 version. Anyone knows where I can download older version ?
Here is the error from the log
[06/12/17 14:02:31] Seadrive daemon process crashed with code -1073741819
[06/12/17 14:02:31] Exiting with error: SeaDrive exited unexpectedly
[06/12/17 14:02:31] failed to get seadrive.events: ‘[’ or ‘{’ expected near end of file
[06/12/17 14:02:31] failed to get global sync status:
[06/12/17 14:02:31] failed to get sync errors: unable to decode byte 0xee near ‘p’
[06/12/17 14:02:32] failed to get seadrive.events: ‘[’ or ‘{’ expected near end of file
[06/12/17 14:02:32] failed to get sync notification: ‘[’ or ‘{’ expected near end of file
[06/12/17 14:02:32] failed to get global sync status: ‘[’ or ‘{’ expected near end of file
[06/12/17 14:02:32] failed to get sync errors: unable to decode byte 0xef near ‘x’
[06/12/17 14:02:33] failed to get seadrive.events: ‘[’ or ‘{’ expected near end of file
[06/12/17 14:02:33] failed to get sync notification: ‘[’ or ‘{’ expected near end of file
[06/12/17 14:02:33] failed to get global sync status: ‘[’ or ‘{’ expected near end of file
[06/12/17 14:02:33] failed to get sync errors: unable to decode byte 0xc8
[06/12/17 14:02:34] SeaDrive exited unexpectedly
[06/12/17 14:02:34] app event loop exited with 1
[06/12/17 14:02:34] Unmounting before exit
[06/12/17 14:02:34] [Daemon Mgr] stopping seadrive daemon
Little more on the issue or another case I guess. Trying to compare two folders in side-by-side more through beyond compare. Copying files from one to another crashes the client too same error in the log. Used to work on older version.
Thanks,
