I have upgraded my Seafile server to 6.0.2 and installed the Drive client on my windows machine. In the virtual drive I can only see libraries I created after upgrading the server. The libraries that existed before upgrading are not being synced. I checked the Drive client logs and don’t see any errors but also no messages about the older libraries being synced. Is there any additional steps I need to perform to upgrade libraries when upgrading the server?
No, the libraries are not encrypted. I did find a post about libraries not syncing using http after an upgrade from server version 2.x to 3.0 or later. However the normal drive client does sync fine and I think it is using http so I don’t know that that is the issue. I did upgrade my server from 2.1 to 6.01. When I did the upgrade the time it took to upgrade to 3.0 was several hours compared to only a few seconds for all the other incremental upgrades so I’m assuming it took time to upgrade the library data to the post 3.0 format.
