I got an error in pro 7.1.14 related to SAML provisionning
A user logs into SSO for the first time, the admin needs to activate the account
The admin does not activate the account
The user logs a second time, the account is still unactivated
Then the admin do activate the account
The user tries to log for the third time : he is authorized but the server crashes with this log
File "/home/cc/seafile/seafile-pro-server-7.1.4/seahub/thirdpart/django/core/handlers/exception.py", line 41, in inner
File "/home/cc/seafile/seafile-pro-server-7.1.4/seahub/thirdpart/django/core/handlers/base.py", line 244, in _legacy_get_response
File "/home/cc/seafile/seafile-pro-server-7.1.4/seahub/thirdpart/shibboleth/middleware.py", line 99, in process_request
self.make_profile(user, shib_meta)
File "/home/cc/seafile/seafile-pro-server-7.1.4/seahub/thirdpart/shibboleth/middleware.py", line 166, in make_profile
p.save()
File "/home/cc/seafile/seafile-pro-server-7.1.4/seahub/thirdpart/django/db/models/base.py", line 808, in save
force_update=force_update, update_fields=update_fields)
File "/home/cc/seafile/seafile-pro-server-7.1.4/seahub/thirdpart/django/db/models/base.py", line 838, in save_base
updated = self._save_table(raw, cls, force_insert, force_update, using, update_fields)
File "/home/cc/seafile/seafile-pro-server-7.1.4/seahub/thirdpart/django/db/models/base.py", line 924, in _save_table
result = self._do_insert(cls._base_manager, using, fields, update_pk, raw)
File "/home/cc/seafile/seafile-pro-server-7.1.4/seahub/thirdpart/django/db/models/base.py", line 963, in _do_insert
using=using, raw=raw)
File "/home/cc/seafile/seafile-pro-server-7.1.4/seahub/thirdpart/django/db/models/manager.py", line 85, in manager_method
return getattr(self.get_queryset(), name)(*args, **kwargs)
File "/home/cc/seafile/seafile-pro-server-7.1.4/seahub/thirdpart/django/db/models/query.py", line 1079, in _insert
return query.get_compiler(using=using).execute_sql(return_id)
File "/home/cc/seafile/seafile-pro-server-7.1.4/seahub/thirdpart/django/db/models/sql/compiler.py", line 1112, in execute_sql
cursor.execute(sql, params)
File "/home/cc/seafile/seafile-pro-server-7.1.4/seahub/thirdpart/django/db/backends/utils.py", line 64, in execute
File "/home/cc/seafile/seafile-pro-server-7.1.4/seahub/thirdpart/django/db/utils.py", line 94, in __exit__
File "/home/cc/seafile/seafile-pro-server-7.1.4/seahub/thirdpart/django/utils/six.py", line 685, in reraise
raise value.with_traceback(tb)
File "/home/cc/seafile/seafile-pro-server-7.1.4/seahub/thirdpart/django/db/backends/mysql/base.py", line 101, in execute
File "/home/cc/seafile/seafile-pro-server-7.1.4/seahub/thirdpart/pymysql/cursors.py", line 170, in execute
result = self._query(query)
File "/home/cc/seafile/seafile-pro-server-7.1.4/seahub/thirdpart/pymysql/cursors.py", line 328, in _query
conn.query(q)
File "/home/cc/seafile/seafile-pro-server-7.1.4/seahub/thirdpart/pymysql/connections.py", line 517, in query
self._affected_rows = self._read_query_result(unbuffered=unbuffered)
File "/home/cc/seafile/seafile-pro-server-7.1.4/seahub/thirdpart/pymysql/connections.py", line 732, in _read_query_result
result.read()
File "/home/cc/seafile/seafile-pro-server-7.1.4/seahub/thirdpart/pymysql/connections.py", line 1075, in read
first_packet = self.connection._read_packet()
File "/home/cc/seafile/seafile-pro-server-7.1.4/seahub/thirdpart/pymysql/connections.py", line 684, in _read_packet
packet.check_error()
File "/home/cc/seafile/seafile-pro-server-7.1.4/seahub/thirdpart/pymysql/protocol.py", line 220, in check_error
err.raise_mysql_exception(self._data)
File "/home/cc/seafile/seafile-pro-server-7.1.4/seahub/thirdpart/pymysql/err.py", line 109, in raise_mysql_exception
raise errorclass(errno, errval)
django.db.utils.IntegrityError: (1062, "Duplicate entry 'gauburtin@domain.fr' for key 'profile_profile_contact_email_0975e4bf_uniq'")
What can i do to delete the duplicate wihout deletting the user ?
I’m on a test server, i can delete the user but i would like to know how to only delete the duplicate.
I’m quite sure of the scenario, but the duplicate may have another cause.
Regards
