If I try to search anything from the web front-end, I get “Internal server error”. If I disable indexing, I get a spinning circle that never stops spinning.
After updating to 9.0.15 and restarting, Search doesn’t throw an error anymore – it simply returns empty results.
Notable issues:
- The
elasticsearch.pid
file in the/pids
folder is never created. If created manually, gets deleted. - The
/pro-data
folder is completely empty. It looks like it has stayed empty since I converted the standard Seafile to Pro. Permissions to theseafile
user are given correctly. - This may or may not be connected to a “well documented” urllib3-elasticsearch problem in Python. Check
index.log
andpro.py output
below.
seafevents.conf
[INDEX FILES]
enabled = true
interval = 10m
highlight = fvh
controller.log
2023-03-02 15:46:33 seafile-controller.c(97): spawn_process: /opt/seafile/seafile-pro-server-9.0.15/pro/elasticsearch/bin/elasticsearch -Epath.logs=/opt/seafile/logs -Epath.data=/opt/seafile/pro-data/search/data -Enetwork.host=127.0.0.1 -p /opt/seafile/pids/elasticsearch.pid
2023-03-02 15:46:33 seafile-controller.c(131): spawned /opt/seafile/seafile-pro-server-9.0.15/pro/elasticsearch/bin/elasticsearch, pid 2478649
2023-03-02 15:46:33 seafile-controller.c(119): failed to execvp /opt/seafile/seafile-pro-server-9.0.15/pro/elasticsearch/bin/elasticsearch
^ I tried solving the above by creating a soft link to the correct path of elasticsearch (since there is no /bin/elasticsearch
folder), as suggested here. The error may have disappeared from the log, I think. But all the other problems remain.
index.log
03/02/2023 11:49:47 [INFO] seafes:208 main: storage: using filesystem storage backend
03/02/2023 11:49:47 [INFO] seafes:210 main: index office pdf: False
03/02/2023 11:49:47 [ERROR] seafes:158 start_index_local: Index process init error: ConnectionError(<urllib3.connection.HTTPConnection object at 0x7f81bf91ea00>: Failed to establish a new connection: [Errno 111] Connection refused) caused by: NewConnectionError(<urllib3.connection.HTTPConnection object at 0x7f81bf91ea00>: Failed to establish a new connection: [Errno 111] Connection refused).
seafevents.log
[2023-03-02 11:39:47,302] [INFO] search indexer is started, interval = 600 sec
[2023-03-02 11:39:47,302] [INFO] seahub email sender is disabled
[2023-03-02 11:39:47,302] [INFO] ldap sync is disabled
[2023-03-02 11:39:47,302] [INFO] virus scan is disabled
[2023-03-02 11:39:47,302] [INFO] data statistics is disabled
[2023-03-02 11:39:47,302] [INFO] content scan is disabled
[2023-03-02 11:39:47,303] [INFO] repo old file auto del scanner disabled
[2023-03-02 11:39:47,303] [INFO] User login statistics is disabled.
[2023-03-02 11:39:47,303] [INFO] Traffic statistics is disabled.
[2023-03-02 11:49:47,303] [INFO] starts to index files
<pro.py search --clear> output
File "/opt/seafile/seafile-pro-server-9.0.15/pro/python/elasticsearch/connection/http_urllib3.py", line 280, in perform_request raise ConnectionError("N/A", str(e), e) elasticsearch.exceptions.ConnectionError: ConnectionError(<urllib3.connection.HTTPConnection object at 0x7f1787f72670>: Failed to establish a new connection: [Errno 111] Connection refused) caused by: NewConnectionError(<urllib3.connection.HTTPConnection object at 0x7f1787f72670>: Failed to establish a new connection: [Errno 111] Connection refused)
The urllib3 - elasticsearch - error 111 - python problem is well recorded on Google, but I cannot seem to find a solution that can help in this case.
Any idea on how to fix all of this will be very very welcomed.
