Encrypting a pre-existing library?
I looked through the manual and the forums but I can’t seem to find a way to encrypt a library that already exists, perhaps I’m missing the setting?
I’m using the W7 0.6.0 client and I understand that it doesn’t currently support encrypted libraries. So I’d like to start using it unencrypted and then have the ability to later convert it to an encrypted library. Is this possible?
Thank you for your time and consideration.
It is not possible to modify a library once created, I also wanted to do it, but the function does not exist yet …
