Hello, has anyone successfully used Cryptomator with SeaDrive? I’m on Win10 and it can’t create its Vault inside My Libraries folder. I create Cryptomator folder inside that folder and it allows me to create a vault, but then returns this error:
java.io.IOException: Error during file system creation.` at org.cryptomator.cryptofs.CryptoFileSystems.create(CryptoFileSystems.java:53) at org.cryptomator.cryptofs.CryptoFileSystemProvider.newFileSystem(CryptoFileSystemProvider.java:302) at org.cryptomator.cryptofs.CryptoFileSystemProvider.newFileSystem(CryptoFileSystemProvider.java:94) at java.base/java.nio.file.FileSystems.newFileSystem(Unknown Source) at java.base/java.nio.file.FileSystems.newFileSystem(Unknown Source) at org.cryptomator.cryptofs.CryptoFileSystemProvider.newFileSystem(CryptoFileSystemProvider.java:135) at org.cryptomator.ui.addvaultwizard.CreateNewVaultPasswordController.initializeVault(CreateNewVaultPasswordController.java:173) at org.cryptomator.ui.addvaultwizard.CreateNewVaultPasswordController.lambda$showSuccessScene$5(CreateNewVaultPasswordController.java:152) at org.cryptomator.ui.common.Tasks.lambda$create$0(Tasks.java:33) at org.cryptomator.ui.common.Tasks$TaskImpl.call(Tasks.java:139) at javafx.concurrent.Task$TaskCallable.call(Task.java:1425) at java.base/java.util.concurrent.FutureTask.run(Unknown Source) at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) at java.base/java.util.concurrent.FutureTask.run(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at java.base/java.lang.Thread.run(Unknown Source) Caused by: java.io.UncheckedIOException: java.nio.file.NoSuchFileException: A:\My Libraries\Cryptomator\Folder at org.cryptomator.cryptofs.CryptoFileStore.getFileStore(CryptoFileStore.java:40) at org.cryptomator.cryptofs.CryptoFileStore.<init>(CryptoFileStore.java:31) at org.cryptomator.cryptofs.CryptoFileStore_Factory.newInstance(CryptoFileStore_Factory.java:38) at org.cryptomator.cryptofs.CryptoFileStore_Factory.get(CryptoFileStore_Factory.java:29) at org.cryptomator.cryptofs.CryptoFileStore_Factory.get(CryptoFileStore_Factory.java:8) at dagger.internal.DoubleCheck.get(DoubleCheck.java:47) at org.cryptomator.cryptofs.CryptoFileSystemImpl_Factory.get(CryptoFileSystemImpl_Factory.java:110) at org.cryptomator.cryptofs.CryptoFileSystemImpl_Factory.get(CryptoFileSystemImpl_Factory.java:16) at dagger.internal.DoubleCheck.get(DoubleCheck.java:47) at org.cryptomator.cryptofs.DaggerCryptoFileSystemProviderComponent$CryptoFileSystemComponentImpl.cryptoFileSystem(DaggerCryptoFileSystemProviderComponent.java:325) at org.cryptomator.cryptofs.CryptoFileSystems.lambda$create$0(CryptoFileSystems.java:47) at java.base/java.util.concurrent.ConcurrentHashMap.compute(Unknown Source) at org.cryptomator.cryptofs.CryptoFileSystems.create(CryptoFileSystems.java:40) ... 16 more Caused by: java.nio.file.NoSuchFileException: A:\My Libraries\Cryptomator\Folder at java.base/sun.nio.fs.WindowsException.translateToIOException(Unknown Source) at java.base/sun.nio.fs.WindowsException.rethrowAsIOException(Unknown Source) at java.base/sun.nio.fs.WindowsException.rethrowAsIOException(Unknown Source) at java.base/sun.nio.fs.WindowsLinkSupport.getFinalPath(Unknown Source) at java.base/sun.nio.fs.WindowsFileStore.create(Unknown Source) at java.base/sun.nio.fs.WindowsFileSystemProvider.getFileStore(Unknown Source) at org.cryptomator.cryptofs.CryptoFileStore.getFileStore(CryptoFileStore.java:38) ... 28 more
if i can’t use cryptomator with SeaDrive, what can i use to encrypt my SeaFile cloud drive?
