Entered token is not valid when creating a two-factor token
Hi All,
Entered token is not valid when creating a two-factor token.
The token is configured in Google and MS Authenticator to try it out, but there is no way to get this working.
Version: 6.0.13 (Pro)
Is there something required in the config? How can I get this resolved?
Thanks…!
mostly this is a time problem. so double chack all time and timezone settings.
use of ntp-server like pool.ntp.org is mandatory
Yes, thanks! Fixed by syncing the time again.
In my case: vzctl set X --capability sys_time:on --save for OpenVZ to give the container access to the kernel.
