I have created the Seafile container using the following files:
.env:
COMPOSE_FILE='seafile-server.yml,caddy.yml,seadoc.yml'
COMPOSE_PATH_SEPARATOR=','
SEAFILE_IMAGE=seafileltd/seafile-mc:12.0-latest
SEAFILE_MEMCACHED_IMAGE=memcached:1.6.29
SEAFILE_CADDY_IMAGE=lucaslorentz/caddy-docker-proxy:2.9-alpine
SEAFILE_VOLUME=/opt/seafile-data
SEAFILE_MYSQL_VOLUME=/opt/seafile-mysql/db
SEAFILE_CADDY_VOLUME=/opt/seafile-caddy
SEAFILE_MYSQL_DB_HOST=db
INIT_SEAFILE_MYSQL_ROOT_PASSWORD=ROOT_PASSWORD
SEAFILE_MYSQL_DB_USER=seafile
SEAFILE_MYSQL_DB_PASSWORD=PASSWORD
TIME_ZONE=Europe/Paris
JWT_PRIVATE_KEY=QwkBFDGyUCk9DmDkg1Bn7u2fmnweZF3KuFeDlHuR
SEAFILE_SERVER_HOSTNAME=seafile.tftm.fr
SEAFILE_SERVER_PROTOCOL=https
INIT_SEAFILE_ADMIN_EMAIL=massardier.camille@gmail.com
INIT_SEAFILE_ADMIN_PASSWORD=asecret
SEADOC_IMAGE=seafileltd/sdoc-server:1.0-latest
SEADOC_VOLUME=/opt/seadoc-data
ENABLE_SEADOC=true
NOTIFICATION_SERVER_IMAGE=seafileltd/notification-server:12.0-latest
NOTIFICATION_SERVER_VOLUME=/opt/notification-data
caddy.yml:
caddy:
restart: unless-stopped
container_name: seafile-caddy
- 4431:443
- /var/run/docker.sock:/var/run/docker.sock
- ${SEAFILE_CADDY_VOLUME:-/opt/seafile-caddy}:/data/caddy
networks:
- seafile-net
healthcheck:
test: ["CMD-SHELL", "curl --fail http://localhost:2019/metrics || exit 1"]
start_period: 20s
interval: 20s
timeout: 5s
retries: 3
networks:
seafile-net:
seadoc.yml:
seadoc:
image: ${SEADOC_IMAGE:-seafileltd/sdoc-server:1.0-latest}
container_name: seadoc
- ${SEADOC_VOLUME:-/opt/seadoc-data/}:/shared
# ports:
# - "80:80"
- DB_PORT=${SEAFILE_MYSQL_DB_PORT:-3306}
- DB_USER=${SEAFILE_MYSQL_DB_USER:-seafile}
- DB_PASSWORD=${SEAFILE_MYSQL_DB_PASSWORD:?Variable is not set or empty}
- DB_NAME=${SEADOC_MYSQL_DB_NAME:-seahub_db}
- TIME_ZONE=${TIME_ZONE:-Etc/UTC}
- JWT_PRIVATE_KEY=${JWT_PRIVATE_KEY:?Variable is not set or empty}
- NON_ROOT=${NON_ROOT:-false}
- SEAHUB_SERVICE_URL=${SEAFILE_SERVER_PROTOCOL:-http}://${SEAFILE_SERVER_HOSTNAME:?Variable is not set or empty}
labels:
caddy: ${SEAFILE_SERVER_PROTOCOL:-http}://${SEAFILE_SERVER_HOSTNAME:?Variable is not set or empty}
caddy.@ws.0_header: "Connection *Upgrade*"
caddy.@ws.1_header: "Upgrade websocket"
caddy.0_reverse_proxy: "@ws {{upstreams 80}}"
caddy.1_handle_path: "/socket.io/*"
caddy.1_handle_path.0_rewrite: "* /socket.io{uri}"
caddy.1_handle_path.1_reverse_proxy: "{{upstreams 80}}"
caddy.2_handle_path: "/sdoc-server/*"
caddy.2_handle_path.0_rewrite: "* {uri}"
caddy.2_handle_path.1_reverse_proxy: "{{upstreams 80}}"
depends_on:
db:
condition: service_healthy
networks:
- seafile-net
networks:
seafile-net:
seafile-server.yml:
db:
image: ${SEAFILE_DB_IMAGE:-mariadb:10.11}
container_name: seafile-mysql
- MYSQL_ROOT_PASSWORD=${INIT_SEAFILE_MYSQL_ROOT_PASSWORD:-}
- MYSQL_LOG_CONSOLE=true
- MARIADB_AUTO_UPGRADE=1
- "${SEAFILE_MYSQL_VOLUME:-/opt/seafile-mysql/db}:/var/lib/mysql"
networks:
- seafile-net
healthcheck:
test:
"CMD",
"/usr/local/bin/healthcheck.sh",
"--connect",
"--mariadbupgrade",
"--innodb_initialized",
interval: 20s
start_period: 30s
timeout: 5s
retries: 10
memcached:
image: ${SEAFILE_MEMCACHED_IMAGE:-memcached:1.6.29}
entrypoint: memcached -m 256
networks:
- seafile-net
seafile:
image: ${SEAFILE_IMAGE:-seafileltd/seafile-mc:12.0-latest}
# ports:
# - "80:80"
- DB_ROOT_PASSWD=${INIT_SEAFILE_MYSQL_ROOT_PASSWORD:-}
- SEAFILE_MYSQL_DB_CCNET_DB_NAME=${SEAFILE_MYSQL_DB_CCNET_DB_NAME:-ccnet_db}
- SEAFILE_MYSQL_DB_SEAFILE_DB_NAME=${SEAFILE_MYSQL_DB_SEAFILE_DB_NAME:-seafile_db}
- SEAFILE_MYSQL_DB_SEAHUB_DB_NAME=${SEAFILE_MYSQL_DB_SEAHUB_DB_NAME:-seahub_db}
- INIT_SEAFILE_ADMIN_EMAIL=${INIT_SEAFILE_ADMIN_EMAIL:-me@example.com}
- INIT_SEAFILE_ADMIN_PASSWORD=${INIT_SEAFILE_ADMIN_PASSWORD:-asecret}
- SEAFILE_SERVER_HOSTNAME=${SEAFILE_SERVER_HOSTNAME:?Variable is not set or empty}
- SEAFILE_SERVER_PROTOCOL=${SEAFILE_SERVER_PROTOCOL:-http}
- SITE_ROOT=${SITE_ROOT:-/}
- SEAFILE_LOG_TO_STDOUT=${SEAFILE_LOG_TO_STDOUT:-false}
- ENABLE_SEADOC=${ENABLE_SEADOC:-true}
- SEADOC_SERVER_URL=${SEAFILE_SERVER_PROTOCOL:-http}://${SEAFILE_SERVER_HOSTNAME:?Variable is not set or empty}/sdoc-server
labels:
depends_on:
db:
memcached:
condition: service_started
networks:
- seafile-net
networks:
seafile-net:
I am using Nginx version 1.26.3
with the following config file:
listen 80;
server_name seafile.tftm.fr;
listen 443 ssl;
ssl_certificate /etc/letsencrypt/live/seafile.tftm.fr/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/seafile.tftm.fr/privkey.pem;
proxy_pass http://127.0.0.1:801;
proxy_set_header Host $host;
My problem is that I get stuck in a redirection loop, leading to the ERR_TOO_MANY_REDIRECTS
error.
Here’s the log from the network tab of the devtools:
Please help me!
