can u login back in, and create the new folder in new library , then try synchronize.
Yes, but the result is similar.
It’s a stupid question but I want make it clear. Are you sure that you have installed PRO version, don’t mean you purchase it, I’m asking about version exactly installed on your server. I have CE and have same error after try it(this is only PRO feature).
Yes, I have a PRO version for 3 people and earlier this function worked, but after a new installation on a new server, this error arose. The rest of the PRO functions work.
The CE version also supports the synchronization of subfolders
So there is some mismatch in DOC
Hmmmm…
In that case, I do not know. But my version is PRO
Now, I re-install Seafile 6.2.0 to 6.1.9 Pro version and error disappeared. WTF
Apparently an error in the server itself.
this problem exact exists and has been fixed in next version
thanks for your reply
Thanks you)
Hi
I have the same in CE 6.3.4.
So we should just wait for the release of the next version, correct?
Oh, I just realize that this is from November 2017.
I will open a new topic.
