I did upgrade to 6.2.3 today and after that I get this error in seahub.log:
2017-11-15 08:39:49,783 [ERROR] django.pylibmc:132 get MemcachedError: error 26 from memcached_get(:1:CUR_TOPINFO): Broken pipe
File “/usr/local/lib/python2.7/dist-packages/django_pylibmc/memcached.py”, line 130, in get
return super(PyLibMCCache, self).get(key, default, version)
File “/home/seafile/nohatech/seafile-server-6.2.3/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/core/cache/backends/memcached.py”, line 84, in get
val = self._cache.get(key)
2017-11-15 08:39:49,866 [ERROR] django.pylibmc:132 get MemcachedError: error 26 from memcached_get(:1:CUR_TOPINFO): Broken pipe
2017-11-15 08:39:49,880 [ERROR] django.pylibmc:132 get MemcachedError: error 26 from memcached_get(:1:CUR_TOPINFO): Broken pipe
2017-11-15 08:39:49,892 [ERROR] django.pylibmc:132 get MemcachedError: error 26 from memcached_get(:1:CUR_TOPINFO): Broken pipe
I have tried to delete the memcached.sock and also I have tried to clear the cache for memcached nothing works =/
When I did update from 6.2.2 to 6.2.3 I started to get the same issue as you, so I did revert back to the old settings for seahub_settings.py and that works without any issues.
and also if you get error with my example above try to delete the unix: in location.
Ok, good!
What version of Seafile are you running? @Cisco can you also try the same as @gauburtin to see if that solves your issue also?
Shifting to the old setup.
