Error on GPO upgrade - error 2753
An error occurs during deployment of new seafile client MSI on Windows by GPO
Pictures attached
Any suggestion?
Did you found any solution for this error? I have the same problem when i upgrade seafile.
I found a more detailed error message in windows event log.
Product: Seafile 6.1.3 – The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2753. The arguments are: seafileapplet.exe
How can we solve this?
Thanks
go to the registry and search for “seafile” delete all Seafile Version keys you find. After that start the installation again
I open ‘regedit’, delete all Seafile keys, reboot the system. Start installation but the problem still exists. Nothing changed.
Anything else i missed?
