On Trisquel 9, I followed the instructions at https://manual.seafile.com/deploy/using_sqlite/ using 8.0.2 for a fresh install.
I created a seafile user that owns the installation files and runs all the commands. When setting up the admin, I used the same name. I used a hostname that resolves correctly, but I only redirected ports 8082 and 8000 to the host (I am behind NAT).
At the step of starting Seahub, this is what happens:
seafile@albert:~/seafile-server-8.0.2$ ./seahub.sh start
Error:Seahub failed to start.
If I try again, possibly with another port, the same happens. Setting LC_ALL removes the message on LC_ALL but it fails the same.
I have the following packages:
Souhait=inconnU/Installé/suppRimé/Purgé/H=à garder
| État=Non/Installé/fichier-Config/dépaqUeté/échec-conFig/H=semi-installé/W=attend-traitement-déclenchements
|/ Err?=(aucune)/besoin Réinstallation (État,Err: majuscule=mauvais)
||/ Nom Version Architecture Description
ii libpython2.7:amd64 2.7.17-1~18.04ubu amd64 Shared Python runtime library (version 2.7)
ii python-ldap 3.0.0-1ubuntu0.1 amd64 LDAP interface module for Python
ii python-requests 2.18.4-2ubuntu0.1 all elegant and simple HTTP library for Python2, built for h
ii python-setuptools 39.0.1-2 all Python Distutils Enhancements
ii python-urllib3 1.22-1ubuntu0.18. all HTTP library with thread-safe connection pooling for Pyt
ii python2.7 2.7.17-1~18.04ubu amd64 Interactive high-level object-oriented language (version
ii sqlite3 3.22.0-1ubuntu0.4 amd64 Command line interface for SQLite 3
david@albert:~$
Is there something wrong in there?
