Hello
Please help us with a synchronization problem at desktop client on windows.
[05/20/19 15:39:46] seaf-daemon.c(491): starting seafile client 6.2.9
[05/20/19 15:39:46] seaf-daemon.c(493): seafile source code version dd49e4bc26623162c8b7d5ae29c17927d3bf6718
[05/20/19 15:39:46] seafile-session.c(382): client id = 471469398814a1488337f16abe94bbadb0bac5be, client_name = M01DSFD06
[05/20/19 15:39:47] seaf-daemon.c(518): rpc server started.
[05/20/19 15:39:47] clone-mgr.c(715): Transition clone state for 07f504dd from [init] to [check server].
[05/20/19 15:39:47] clone-mgr.c(715): Transition clone state for 064fd475 from [init] to [check server].
[05/20/19 15:39:49] [05/20/19 15:39:49] clone-mgr.c(715): Transition clone state for 064fd475 from [check server] to [fetch].
http-tx-mgr.c(1181): Transfer repo ‘064fd475’: (‘normal’, ‘init’) --> (‘normal’, ‘check’)
[05/20/19 15:39:49] http-tx-mgr.c(1181): Transfer repo ‘064fd475’: (‘normal’, ‘check’) --> (‘normal’, ‘commit’)
[05/20/19 15:39:49] http-tx-mgr.c(1181): Transfer repo ‘064fd475’: (‘normal’, ‘commit’) --> (‘normal’, ‘fs’)
[05/20/19 15:39:49] sync-mgr.c(1323): File syncing protocol version on server https://doc.renlife.com is 2. Client file syncing protocol version is 2. Use version 2.
[05/20/19 15:39:49] [05/20/19 15:39:49] clone-mgr.c(715): Transition clone state for 07f504dd from [check server] to [fetch].
http-tx-mgr.c(1181): Transfer repo ‘07f504dd’: (‘normal’, ‘init’) --> (‘normal’, ‘check’)
[05/20/19 15:39:49] http-tx-mgr.c(1181): Transfer repo ‘07f504dd’: (‘normal’, ‘check’) --> (‘normal’, ‘commit’)
[05/20/19 15:39:49] http-tx-mgr.c(1181): Transfer repo ‘07f504dd’: (‘normal’, ‘commit’) --> (‘normal’, ‘fs’)
[05/20/19 15:39:49] http-tx-mgr.c(1181): Transfer repo ‘07f504dd’: (‘normal’, ‘fs’) --> (‘normal’, ‘data’)
[05/20/19 15:39:49] http-tx-mgr.c(1181): Transfer repo ‘064fd475’: (‘normal’, ‘fs’) --> (‘normal’, ‘data’)
[05/20/19 15:39:49] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/07f504dd-54ca-476b-a171-50be6d9dd4a6/block/b808ff79fae2ab502097b39a0e336afadd096570: 500.
[05/20/19 15:39:49] repo-mgr.c(4356): Transfer failed.
[05/20/19 15:39:49] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/07f504dd-54ca-476b-a171-50be6d9dd4a6/block/6bf896137be6ed99ec6d41c43b946bc3fc8d2de5: 500.
[05/20/19 15:39:49] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/07f504dd-54ca-476b-a171-50be6d9dd4a6/block/1e732eeac42c74c281754d7275e3d271fe3dcf3b: 500.
[05/20/19 15:39:49] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/064fd475-3038-4b80-9c46-c1ef626beaf6/block/47c964d80bf34a4dcdc4e92023abddefb219270e: 500.
[05/20/19 15:39:49] sync-mgr.c(559): Repo ‘Моя библиотека’ sync state transition from ‘synchronized’ to ‘committing’.
[05/20/19 15:39:49] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/064fd475-3038-4b80-9c46-c1ef626beaf6/block/6c59174c624bfc24693a630aa9dde00ff21527bc: 500.
[05/20/19 15:39:49] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/064fd475-3038-4b80-9c46-c1ef626beaf6/block/aa0466a602d225d0a8fc34443b6b411ed1919add: 500.
[05/20/19 15:39:49] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/064fd475-3038-4b80-9c46-c1ef626beaf6/block/8d9a5bbccedfabc5c9756d4b2edef6b904a8dcb2: 500.
[05/20/19 15:39:49] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/07f504dd-54ca-476b-a171-50be6d9dd4a6/block/057f6766b1ab050e171de08d27dba6b929d14d19: 500.
[05/20/19 15:39:49] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/064fd475-3038-4b80-9c46-c1ef626beaf6/block/bcf2aeca27deca77c40fa47c57e4a223638e61b3: 500.
[05/20/19 15:39:49] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/064fd475-3038-4b80-9c46-c1ef626beaf6/block/f423f3e6844a267aced0ef67460f465b6791d0e3: 500.
[05/20/19 15:39:49] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/064fd475-3038-4b80-9c46-c1ef626beaf6/block/cedfdd7ed5287c7634426e290b8a46f27518251f: 500.
[05/20/19 15:39:49] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/064fd475-3038-4b80-9c46-c1ef626beaf6/block/aec915f81b39251d41f488e0ec6fdb5448bfa897: 500.
[05/20/19 15:39:49] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/064fd475-3038-4b80-9c46-c1ef626beaf6/block/4908ab51682e7b9710544038e7d1d2b3800d328a: 500.
[05/20/19 15:39:49] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/064fd475-3038-4b80-9c46-c1ef626beaf6/block/2b877758f8208f415cdedc9e03104c11927a31c0: 500.
[05/20/19 15:39:49] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/064fd475-3038-4b80-9c46-c1ef626beaf6/block/2b56e10b9199886c00c8b6c8da39a7fbd12186cf: 500.
[05/20/19 15:39:49] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/064fd475-3038-4b80-9c46-c1ef626beaf6/block/2f6fe7bdbbe33fe7674dba822e263cbd8927033d: 500.
[05/20/19 15:39:49] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/064fd475-3038-4b80-9c46-c1ef626beaf6/block/a6f2682bcfea8340a68afa2acf0883108e560e60: 500.
[05/20/19 15:39:49] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/064fd475-3038-4b80-9c46-c1ef626beaf6/block/19e1d15f3e2f1d7cdcd337c190dc170f6a107fcb: 500.
[05/20/19 15:39:49] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/064fd475-3038-4b80-9c46-c1ef626beaf6/block/ff40e493db575b07492f10f50d19cb72e465843e: 500.
[05/20/19 15:39:49] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/064fd475-3038-4b80-9c46-c1ef626beaf6/block/dc02061da99c4f7d21915813bf2d800018b48937: 500.
[05/20/19 15:39:49] repo-mgr.c(3799): All events are processed for repo 762d2d7d-8d26-4c6c-9934-c814a3ec9729.
[05/20/19 15:39:49] [05/20/19 15:39:49] http-tx-mgr.c(1181): Transfer repo ‘07f504dd’: (‘normal’, ‘data’) --> (‘error’, ‘finished’)
[05/20/19 15:39:49] clone-mgr.c(732): Transition clone state for 07f504dd from [fetch] to [error]: fetch.
[05/20/19 15:39:49] http-tx-mgr.c(808): libcurl failed to GET https://doc.renlife.com/seafhttp/repo/064fd475-3038-4b80-9c46-c1ef626beaf6/block/4d153014c450d102cdb7ab7067a4543b0363b8a0: Failed writing received data to disk/application.
[05/20/19 15:39:49] http-tx-mgr.c(808): libcurl failed to GET https://doc.renlife.com/seafhttp/repo/064fd475-3038-4b80-9c46-c1ef626beaf6/block/fb0255f44ef070a20e47028bc6dfe76d676e5819: Failed writing received data to disk/application.
[05/20/19 15:39:49] http-tx-mgr.c(808): libcurl failed to GET https://doc.renlife.com/seafhttp/repo/064fd475-3038-4b80-9c46-c1ef626beaf6/block/1710ef59e5f6ef46cbeabb4d22f534205ac530f2: Failed writing received data to disk/application.
[05/20/19 15:39:49] sync-mgr.c(559): Repo ‘Моя библиотека’ sync state transition from ‘committing’ to ‘initializing’.
[05/20/19 15:39:49] http-tx-mgr.c(1181): Transfer repo ‘064fd475’: (‘normal’, ‘data’) --> (‘error’, ‘finished’)
[05/20/19 15:39:49] clone-mgr.c(732): Transition clone state for 064fd475 from [fetch] to [error]: fetch.
[05/20/19 15:40:02] clone-mgr.c(715): Transition clone state for 9c46acc5 from [init] to [check server].
[05/20/19 15:40:02] [05/20/19 15:40:02] clone-mgr.c(715): Transition clone state for 9c46acc5 from [check server] to [fetch].
http-tx-mgr.c(1181): Transfer repo ‘9c46acc5’: (‘normal’, ‘init’) --> (‘normal’, ‘check’)
[05/20/19 15:40:02] http-tx-mgr.c(1181): Transfer repo ‘9c46acc5’: (‘normal’, ‘check’) --> (‘normal’, ‘commit’)
[05/20/19 15:40:02] http-tx-mgr.c(1181): Transfer repo ‘9c46acc5’: (‘normal’, ‘commit’) --> (‘normal’, ‘fs’)
[05/20/19 15:40:03] http-tx-mgr.c(1181): Transfer repo ‘9c46acc5’: (‘normal’, ‘fs’) --> (‘normal’, ‘data’)
[05/20/19 15:40:03] [05/20/19 15:40:03] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/9c46acc5-96da-4929-b9b3-91440ee53007/block/5116f98dcc5455b5125d313668de9a9f338822db: 500.
http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/9c46acc5-96da-4929-b9b3-91440ee53007/block/f92d9604e63328787e9238aea519302ca3050510: 500.
[05/20/19 15:40:03] repo-mgr.c(4356): Transfer failed.
[05/20/19 15:40:03] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/9c46acc5-96da-4929-b9b3-91440ee53007/block/f7c962572f792960020bdab9f679d4618e1a3ceb: 500.
[05/20/19 15:40:03] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/9c46acc5-96da-4929-b9b3-91440ee53007/block/e59c0dd3fd72d0821c80895696700535c5c7a623: 500.
[05/20/19 15:40:03] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/9c46acc5-96da-4929-b9b3-91440ee53007/block/dbdc630e4912d7cf52b3cf2c0514ad4dd974a574: 500.
[05/20/19 15:40:03] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/9c46acc5-96da-4929-b9b3-91440ee53007/block/04c48dae511c696abfa8b12b5a5158bf85c647f7: 500.
[05/20/19 15:40:03] [05/20/19 15:40:03] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/9c46acc5-96da-4929-b9b3-91440ee53007/block/0baac545f0cd94ca0914dc86bf7a06d841a81105: 500.
http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/9c46acc5-96da-4929-b9b3-91440ee53007/block/83f71892cd857ee49498c061bfa95a7d7d591587: 500.
[05/20/19 15:40:03] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/9c46acc5-96da-4929-b9b3-91440ee53007/block/b4ca3ca48a943e3ca47bbecda4f24adaea00b305: 500.
[05/20/19 15:40:03] [05/20/19 15:40:03] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/9c46acc5-96da-4929-b9b3-91440ee53007/block/13db7c73b58b6df350551d00e80e684786896738: 500.
http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/9c46acc5-96da-4929-b9b3-91440ee53007/block/59b240c9a9df02a087c539544af126ebdf297021: 500.
[05/20/19 15:40:03] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/9c46acc5-96da-4929-b9b3-91440ee53007/block/cc5723fadddf541cd6105ef95e9178ab2956b07c: 500.
[05/20/19 15:40:03] [05/20/19 15:40:03] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/9c46acc5-96da-4929-b9b3-91440ee53007/block/c831799ae44a13091586ae1cbb43157dae09bed5: 500.
http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/9c46acc5-96da-4929-b9b3-91440ee53007/block/e096c33647fab22e634c209a896decee44628d6d: 500.
[05/20/19 15:40:03] [05/20/19 15:40:03] repo-mgr.c(4356): Transfer failed.
[05/20/19 15:40:03] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/9c46acc5-96da-4929-b9b3-91440ee53007/block/5d99fa074fc97bc5a5ef502f5d30db6e1d4e60b9: 500.
[05/20/19 15:40:03] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/9c46acc5-96da-4929-b9b3-91440ee53007/block/76b21cf33bf1b34db91195eb63ed1cbca4c619e6: 500.
[05/20/19 15:40:03] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/9c46acc5-96da-4929-b9b3-91440ee53007/block/ea040115a7735a02446a684224adef67620e3ee4: 500.
[05/20/19 15:40:03] http-tx-mgr.c(4351): Bad response code for GET https://doc.renlife.com/seafhttp/repo/9c46acc5-96da-4929-b9b3-91440ee53007/block/6ca7f1b9f8c3a92c99afc5b386280254ef37876f: 500.
[05/20/19 15:40:03] [05/20/19 15:40:03] http-tx-mgr.c(808): libcurl failed to GET https://doc.renlife.com/seafhttp/repo/9c46acc5-96da-4929-b9b3-91440ee53007/block/93f0084ead34436cbf654737e2618dea3ec9c567: Failed writing received data to disk/application.
http-tx-mgr.c(808): libcurl failed to GET https://doc.renlife.com/seafhttp/repo/9c46acc5-96da-4929-b9b3-91440ee53007/block/68246f40ea972e2f882b053c051076eb6a97b94e: Failed writing received data to disk/application.
[05/20/19 15:40:03] http-tx-mgr.c(808): libcurl failed to GET https://doc.renlife.com/seafhttp/repo/9c46acc5-96da-4929-b9b3-91440ee53007/block/2983aea5772302ebdb9ddae4bb3cdd9488ed8066: Failed writing received data to disk/application.
[05/20/19 15:40:03] http-tx-mgr.c(1181): Transfer repo ‘9c46acc5’: (‘normal’, ‘data’) --> (‘error’, ‘finished’)
[05/20/19 15:40:03] clone-mgr.c(732): Transition clone state for 9c46acc5 from [fetch] to [error]: fetch.
[05/20/19 15:39:46]read id from id file
[05/20/19 15:39:46]starting seaf-daemon: ("-c", “C:/Users/Vasiliy.Skalon/ccnet”, “-d”, “C:/Users/Vasiliy.Skalon/Seafile/seafile-data”, “-w”, “C:/Users/Vasiliy.Skalon/Seafile”)
[05/20/19 15:39:47][Rpc Client] connected to daemon
[05/20/19 15:39:50]Starting the network status detector
[05/20/19 15:39:50][AutoUpdateManager] cancel all download tasks
[05/20/19 15:39:50][AutoUpdateManager] clean file caches db
[05/20/19 15:39:50]starting applet rpc service
[05/20/19 15:39:50]applet rpc service started
[05/20/19 15:39:50][Rpc Client] connected to daemon
[05/20/19 15:39:51][Rpc Client] connected to daemon
[05/20/19 15:39:54][network detector] got a network failure
[05/20/19 15:39:54][api] network error for http://doc.renlife.com/media/avatars/default.png: Connection refused
[05/20/19 15:40:00][network detector] resetting the qt network access manager
