Errors after upgrading to 6.02 Pro Server
I upgraded from 5.1.4 to 6.02 version on a debian linux distrib.
No problem during the install, but :
  • The front web interface is slow when displaying libraries
  • The Sync client 6.0 (shibboleth) does not sync nor upload files nor folders
I have these logs :
tail controller. log
[11/10/16 17:41:36] seafile-controller.c(575): pid file /home/cc/seafile/pids/seafevents.pid does not exist
[11/10/16 17:41:36] seafile-controller.c(600): seafevents need restart...
[11/10/16 17:41:36] seafile-controller.c(87): spawn_process: /usr/bin/python2.7 -m seafevents.main --config-file /home/cc/seafile/conf/seafevents.conf --loglevel debug --logfile /home/cc/seafile/logs/seafevents.log -P /home/cc/seafile/pids/seafevents.pid
[11/10/16 17:41:36] seafile-controller.c(102): spawned /usr/bin/python2.7, pid 18524
[11/10/16 17:41:46] seafile-controller.c(575): pid file /home/cc/seafile/pids/seafevents.pid does not exist
[11/10/16 17:41:46] seafile-controller.c(600): seafevents need restart...
[11/10/16 17:41:46] seafile-controller.c(87): spawn_process: /usr/bin/python2.7 -m seafevents.main --config-file /home/cc/seafile/conf/seafevents.conf --loglevel debug --logfile /home/cc/seafile/logs/seafevents.log -P /home/cc/seafile/pids/seafevents.pid
[11/10/16 17:41:46] seafile-controller.c(102): spawned /usr/bin/python2.7, pid 18543
tail ccnet.log
[11/10/16 17:41:07] ../common/session.c(405): Accepted a local client
[11/10/16 17:41:07] ../common/peer.c(950): Local peer down
[11/10/16 17:41:07] ../common/peer.c(948): libevent got an error! what=33, errno=104 (Connection reset by peer)
[11/10/16 17:41:17] ../common/session.c(405): Accepted a local client
[11/10/16 17:41:17] ../common/peer.c(950): Local peer down
[11/10/16 17:41:17] ../common/peer.c(948): libevent got an error! what=33, errno=104 (Connection reset by peer)
[11/10/16 17:41:27] ../common/session.c(405): Accepted a local client
[11/10/16 17:41:27] ../common/peer.c(950): Local peer down
[11/10/16 17:41:27] ../common/peer.c(948): libevent got an error! what=33, errno=104 (Connection reset by peer)
[11/10/16 17:41:37] ../common/session.c(405): Accepted a local client
[11/10/16 17:41:37] ../common/peer.c(950): Local peer down
[11/10/16 17:41:37] ../common/peer.c(948): libevent got an error! what=33, errno=104 (Connection reset by peer)
[11/10/16 17:41:47] ../common/session.c(405): Accepted a local client
[11/10/16 17:41:47] ../common/peer.c(950): Local peer down
[11/10/16 17:41:47] ../common/peer.c(948): libevent got an error! what=33, errno=104 (Connection reset by peer)
[11/10/16 17:41:57] ../common/session.c(405): Accepted a local client
[11/10/16 17:41:57] ../common/peer.c(950): Local peer down
[11/10/16 17:41:57] ../common/peer.c(948): libevent got an error! what=33, errno=104 (Connection reset by peer)
[11/10/16 17:42:07] ../common/session.c(405): Accepted a local client
[11/10/16 17:42:07] ../common/peer.c(950): Local peer down
Restarting seafile.sehub has no effect
Here is the log seafile.log from the sync client
[11/10/16 17:24:58] seaf-daemon.c(548): starting seafile client 6.0.0
[11/10/16 17:24:58] seaf-daemon.c(550): seafile source code version bea8cc526ed37b8c9599e5f526d934c8ec90d288
[11/10/16 17:24:58] ../common/mq-mgr.c(60): [mq client] mq cilent is started
[11/10/16 17:24:58] ../common/mq-mgr.c(106): [mq mgr] publish to heartbeat mq: seafile.heartbeat
[11/10/16 17:26:06] clone-mgr.c(819): Transition clone state for 5144d4da from [init] to [connect].
[11/10/16 17:26:06] [11/10/16 17:26:06] clone-mgr.c(819): Transition clone state for 5144d4da from [connect] to [fetch].
http-tx-mgr.c(4130): Download with HTTP sync protocol version 1.
[11/10/16 17:26:06] http-tx-mgr.c(1012): Transfer repo '5144d4da': ('normal', 'init') --> ('normal', 'check')
[11/10/16 17:26:06] http-tx-mgr.c(1012): Transfer repo '5144d4da': ('normal', 'check') --> ('normal', 'commit')
[11/10/16 17:26:06] http-tx-mgr.c(1012): Transfer repo '5144d4da': ('normal', 'commit') --> ('normal', 'fs')
[11/10/16 17:26:06] http-tx-mgr.c(1012): Transfer repo '5144d4da': ('normal', 'fs') --> ('normal', 'data')
[11/10/16 17:26:07] http-tx-mgr.c(1012): Transfer repo '5144d4da': ('normal', 'data') --> ('finished', 'finished')
[11/10/16 17:26:09] clone-mgr.c(819): Transition clone state for 5144d4da from [fetch] to [done].
[11/10/16 17:26:11] sync-mgr.c(660): Repo 'Test' sync state transition from 'synchronized' to 'committing'.
[11/10/16 17:26:11] repo-mgr.c(3592): All events are processed for repo 5144d4da-3063-4feb-b820-c7f4c5c9296f.
[11/10/16 17:26:11] sync-mgr.c(660): Repo 'Test' sync state transition from 'committing' to 'initializing'.
[11/10/16 17:26:31] sync-mgr.c(660): Repo 'Test' sync state transition from 'synchronized' to 'committing'.
[11/10/16 17:26:31] repo-mgr.c(3592): All events are processed for repo 5144d4da-3063-4feb-b820-c7f4c5c9296f.
[11/10/16 17:26:31] sync-mgr.c(660): Repo 'Test' sync state transition from 'committing' to 'uploading'.
[11/10/16 17:26:31] http-tx-mgr.c(3272): Upload with HTTP sync protocol version 1.
[11/10/16 17:26:31] http-tx-mgr.c(1012): Transfer repo '5144d4da': ('normal', 'init') --> ('normal', 'check')
[11/10/16 17:26:31] http-tx-mgr.c(1012): Transfer repo '5144d4da': ('normal', 'check') --> ('normal', 'commit')
[11/10/16 17:26:31] http-tx-mgr.c(2407): Bad response code for PUT https://server.domain.fr/seafhttp/repo/5144d4da-3063-4feb-b820-c7f4c5c9296f/commit/54ac5396ce2415183606c85c98b85c098476f05a: 500.
[11/10/16 17:26:31] http-tx-mgr.c(3306): Failed to send head commit for repo 5144d4da.
[11/10/16 17:26:31] http-tx-mgr.c(1012): Transfer repo '5144d4da': ('normal', 'commit') --> ('error', 'finished')
[11/10/16 17:26:31] sync-mgr.c(728): Repo 'Test' sync state transition from uploading to 'error': 'Error occured in upload.'.
[11/10/16 17:26:39] sync-mgr.c(660): Repo 'Test' sync state transition from 'synchronized' to 'uploading'.
[11/10/16 17:26:39] http-tx-mgr.c(3272): Upload with HTTP sync protocol version 1.
[11/10/16 17:26:39] http-tx-mgr.c(1012): Transfer repo '5144d4da': ('normal', 'init') --> ('normal', 'check')
[11/10/16 17:26:39] http-tx-mgr.c(1012): Transfer repo '5144d4da': ('normal', 'check') --> ('normal', 'commit')
[11/10/16 17:26:39] http-tx-mgr.c(2407): Bad response code for PUT https://server.domain.fr/seafhttp/repo/5144d4da-3063-4feb-b820-c7f4c5c9296f/commit/54ac5396ce2415183606c85c98b85c098476f05a: 500.
[11/10/16 17:26:39] http-tx-mgr.c(3306): Failed to send head commit for repo 5144d4da.
[11/10/16 17:26:39] http-tx-mgr.c(1012): Transfer repo '5144d4da': ('normal', 'commit') --> ('error', 'finished')
[11/10/16 17:26:39] sync-mgr.c(728): Repo 'Test' sync state transition from uploading to 'error': 'Error occured in upload.'.
[11/10/16 17:27:10] sync-mgr.c(660): Repo 'Test' sync state transition from 'synchronized' to 'uploading'.
[11/10/16 17:27:10] http-tx-mgr.c(3272): Upload with HTTP sync protocol version 1.
[11/10/16 17:27:10] http-tx-mgr.c(1012): Transfer repo '5144d4da': ('normal', 'init') --> ('normal', 'check')
[11/10/16 17:27:10] http-tx-mgr.c(1012): Transfer repo '5144d4da': ('normal', 'check') --> ('normal', 'commit')
[11/10/16 17:27:10] http-tx-mgr.c(2407): Bad response code for PUT https://server.domain.fr/seafhttp/repo/5144d4da-3063-4feb-b820-c7f4c5c9296f/commit/54ac5396ce2415183606c85c98b85c098476f05a: 500.
[11/10/16 17:27:10] http-tx-mgr.c(3306): Failed to send head commit for repo 5144d4da.
[11/10/16 17:27:10] http-tx-mgr.c(1012): Transfer repo '5144d4da': ('normal', 'commit') --> ('error', 'finished')
[11/10/16 17:27:10] sync-mgr.c(728): Repo 'Test' sync state transition from uploading to 'error': 'Error occured in upload.'.
[11/10/16 17:27:19] clone-mgr.c(819): Transition clone state for 5144d4da from [init] to [connect].
[11/10/16 17:27:19] [11/10/16 17:27:19] clone-mgr.c(819): Transition clone state for 5144d4da from [connect] to [fetch].
[11/10/16 17:27:19] http-tx-mgr.c(1012): Transfer repo '5144d4da': ('normal', 'init') --> ('normal', 'check')
[11/10/16 17:27:19] http-tx-mgr.c(1012): Transfer repo '5144d4da': ('normal', 'check') --> ('normal', 'commit')
[11/10/16 17:27:19] http-tx-mgr.c(1012): Transfer repo '5144d4da': ('normal', 'commit') --> ('normal', 'fs')
[11/10/16 17:27:19] http-tx-mgr.c(1012): Transfer repo '5144d4da': ('normal', 'fs') --> ('normal', 'data')
[11/10/16 17:27:20] http-tx-mgr.c(1012): Transfer repo '5144d4da': ('normal', 'data') --> ('finished', 'finished')
[11/10/16 17:27:23] clone-mgr.c(819): Transition clone state for 5144d4da from [fetch] to [done].
[11/10/16 17:27:23] sync-mgr.c(660): Repo 'Test' sync state transition from 'synchronized' to 'committing'.
[11/10/16 17:27:23] repo-mgr.c(3592): All events are processed for repo 5144d4da-3063-4feb-b820-c7f4c5c9296f.
[11/10/16 17:27:23] sync-mgr.c(660): Repo 'Test' sync state transition from 'committing' to 'initializing'.
[11/10/16 17:27:23] sync-mgr.c(1479): Removing blocks for repo Test(5144d4da).
[11/10/16 17:27:59] repo-mgr.c(6485): Removing store D:/Documents/Seafile/seafile-data\deleted_store\commits\5144d4da-3063-4feb-b820-c7f4c5c9296f
[11/10/16 17:27:59] repo-mgr.c(6485): Removing store D:/Documents/Seafile/seafile-data\deleted_store\fs\5144d4da-3063-4feb-b820-c7f4c5c9296f
[11/10/16 17:28:56] http-tx-mgr.c(1266): Bad response code for GET https://server.domain.fr/seafhttp/repo/5144d4da-3063-4feb-b820-c7f4c5c9296f/commit/HEAD: 503.
[11/10/16 17:28:56] sync-mgr.c(728): Repo 'Test' sync state transition from initializing to 'error': 'Failed to get sync info from server.'.
[11/10/16 17:29:27] http-tx-mgr.c(1266): Bad response code for GET https://server.domain.fr/seafhttp/repo/5144d4da-3063-4feb-b820-c7f4c5c9296f/commit/HEAD: 503.
[11/10/16 17:29:27] sync-mgr.c(728): Repo 'Test' sync state transition from initializing to 'error': 'Failed to get sync info from server.'.
[11/10/16 17:29:58] http-tx-mgr.c(1266): Bad response code for GET https://server.domain.fr/seafhttp/repo/5144d4da-3063-4feb-b820-c7f4c5c9296f/commit/HEAD: 503.
[11/10/16 17:29:58] sync-mgr.c(728): Repo 'Test' sync state transition from initializing to 'error': 'Failed to get sync info from server.'.
[11/10/16 17:44:19] seaf-daemon.c(548): starting seafile client 6.0.0
[11/10/16 17:44:19] seaf-daemon.c(550): seafile source code version bea8cc526ed37b8c9599e5f526d934c8ec90d288
[11/10/16 17:44:19] ../common/mq-mgr.c(60): [mq client] mq cilent is started
[11/10/16 17:44:19] ../common/mq-mgr.c(106): [mq mgr] publish to heartbeat mq: seafile.heartbeat
[11/10/16 17:44:21] sync-mgr.c(660): Repo 'Test' sync state transition from 'synchronized' to 'committing'.
[11/10/16 17:44:21] repo-mgr.c(3592): All events are processed for repo 5144d4da-3063-4feb-b820-c7f4c5c9296f.
[11/10/16 17:44:21] sync-mgr.c(660): Repo 'Test' sync state transition from 'committing' to 'initializing'.
Informations from Seadrive 0.4.1 are not good
log seadrive.gui.log
[11/10/16 18:01:41] loaded 0 accounts
[11/10/16 18:01:42] seadrive gui started
[11/10/16 18:01:43] disk letter not set or set but not available
[11/10/16 18:01:51] starting seadrive daemon: seadrive.exe "-d" "C:/Users/gauburtin/seadrive/data" "-l" "C:/Users/gauburtin/seadrive/logs/seadrive.log" "S:"
[11/10/16 18:01:58] seadrive rpc is not ready after 6 retry, abort
[11/10/16 18:01:58] Exiting with error: SeaDrive n'a pu être initialisé
[11/10/16 18:02:01] SeaDrive n'a pu être initialisé
[11/10/16 18:02:01] app event loop exited with 1
[11/10/16 18:02:01] [Daemon Mgr] stopping seadrive daemon
[11/10/16 18:02:01] QProcess: Destroyed while process ("seadrive.exe") is still running.
[11/10/16 18:03:42] loaded 0 accounts
[11/10/16 18:03:42] seadrive gui started
[11/10/16 18:03:42] Using disk leter S:
[11/10/16 18:03:42] starting seadrive daemon: seadrive.exe "-d" "C:/Users/gauburtin/seadrive/data" "-l" "C:/Users/gauburtin/seadrive/logs/seadrive.log" "S:"
[11/10/16 18:04:21] Image of format '' blocked because it is not considered safe. If you are sure it is safe to do so, you can white-list the format by setting the environment variable QTWEBKIT_IMAGEFORMAT_WHITELIST=
[11/10/16 18:04:43] Switched to account https://server.domain.fr webmaster@campus-condorcet.fr df3e452
[11/10/16 18:10:50] Unable to get config value download_limit: Config not exists
[11/10/16 18:10:50] Unable to get config value upload_limit: Config not exists
The computer (Win7) is slow, internet browsers too
I did not try to upload anything
I noticed that seadrive exes are 32 bits. Is there any reason ?
Regards,
Gautier
The first time when you visit the web after upgrade, the server has to generate CSS cache files, so the speed is slow.
Can you check the log file, seafile.log, at the server side?
For the drive client, do you have more logs?
Hi Daniel,
All the facts (logs) were already in the post (that i edited 3 times), but the last version did not show.
Sorry for the delay : i saved the last version one more time (read before). Tell me if you need more
I forgot to mention that the web interface is not functional. I can browse folder but neither read no upload.
Regards
There should be some related errors in seafile.log on the server, which you didn’t post. Could you update that?
Hi, here are the logs frop seafile.log
[11/10/2016 04:52:01 PM] ../common/mq-mgr.c(61): [mq client] mq cilent is started
[11/10/2016 04:52:01 PM] filelock-mgr.c(915): Cleaning expired file locks.
[11/10/2016 05:26:34 PM] ../common/obj-backend-fs.c(288): Failed to create object parent path /nfs/seafile-data/storage/commits/5144d4da-3063-4feb-b820-c7f4c5c9296f/54: Permission denied.
[11/10/2016 05:26:34 PM] ../common/obj-backend-fs.c(316): [obj backend] Failed to create path for obj 5144d4da-3063-4feb-b820-c7f4c5c9296f:54ac5396ce2415183606c85c98b85c098476f05a.
[11/10/2016 05:26:42 PM] ../common/obj-backend-fs.c(288): Failed to create object parent path /nfs/seafile-data/storage/commits/5144d4da-3063-4feb-b820-c7f4c5c9296f/54: Permission denied.
[11/10/2016 05:26:42 PM] ../common/obj-backend-fs.c(316): [obj backend] Failed to create path for obj 5144d4da-3063-4feb-b820-c7f4c5c9296f:54ac5396ce2415183606c85c98b85c098476f05a.
[11/10/2016 05:27:13 PM] ../common/obj-backend-fs.c(288): Failed to create object parent path /nfs/seafile-data/storage/commits/5144d4da-3063-4feb-b820-c7f4c5c9296f/54: Permission denied.
[11/10/2016 05:27:13 PM] ../common/obj-backend-fs.c(316): [obj backend] Failed to create path for obj 5144d4da-3063-4feb-b820-c7f4c5c9296f:54ac5396ce2415183606c85c98b85c098476f05a.
[11/10/2016 05:28:01 PM] ../common/obj-backend-fs.c(288): Failed to create object parent path /nfs/seafile-data/storage/commits/5144d4da-3063-4feb-b820-c7f4c5c9296f/29: Permission denied.
[11/10/2016 05:28:01 PM] ../common/obj-backend-fs.c(316): [obj backend] Failed to create path for obj 5144d4da-3063-4feb-b820-c7f4c5c9296f:296027d796546f88df63102ada4aaf22bfce814a.
[11/10/2016 05:28:01 PM] repo-op.c(474): Failed to add commit.
[11/10/2016 05:28:01 PM] upload-file.c(508): [upload folder] Failed to add commit.[11/10/2016 05:28:49 PM] Disconnected from daemon
[11/10/2016 05:30:03 PM] ../common/mq-mgr.c(61): [mq client] mq cilent is started
[11/10/2016 05:30:03 PM] filelock-mgr.c(915): Cleaning expired file locks.
[11/10/2016 05:31:55 PM] Disconnected from daemon
[11/10/2016 05:32:06 PM] ../common/mq-mgr.c(61): [mq client] mq cilent is started
[11/10/2016 05:32:06 PM] filelock-mgr.c(915): Cleaning expired file locks.
[11/10/2016 05:46:29 PM] ../common/obj-backend-fs.c(288): Failed to create object parent path /nfs/seafile-data/storage/commits/5144d4da-3063-4feb-b820-c7f4c5c9296f/bb: Permission denied.
[11/10/2016 05:46:29 PM] ../common/obj-backend-fs.c(316): [obj backend] Failed to create path for obj 5144d4da-3063-4feb-b820-c7f4c5c9296f:bbb7476a395ad80d95594bf8baf4781173545823.
[11/10/2016 05:46:29 PM] repo-op.c(474): Failed to add commit.
[11/10/2016 06:32:06 PM] filelock-mgr.c(915): Cleaning expired file locks.
[11/10/2016 07:32:06 PM] filelock-mgr.c(915): Cleaning expired file locks.
[11/10/2016 08:32:06 PM] filelock-mgr.c(915): Cleaning expired file locks.
[11/10/2016 09:32:06 PM] filelock-mgr.c(915): Cleaning expired file locks.
[11/10/2016 10:32:06 PM] filelock-mgr.c(915): Cleaning expired file locks.
[11/10/2016 11:32:06 PM] filelock-mgr.c(915): Cleaning expired file locks.
[11/11/2016 12:32:06 AM] filelock-mgr.c(915): Cleaning expired file locks.
[11/11/2016 01:32:06 AM] filelock-mgr.c(915): Cleaning expired file locks.
[11/11/2016 02:32:06 AM] filelock-mgr.c(915): Cleaning expired file locks.
[11/11/2016 03:32:06 AM] filelock-mgr.c(915): Cleaning expired file locks.
[11/11/2016 04:32:06 AM] filelock-mgr.c(915): Cleaning expired file locks.
[11/11/2016 05:32:06 AM] filelock-mgr.c(915): Cleaning expired file locks.
[11/11/2016 06:32:06 AM] filelock-mgr.c(915): Cleaning expired file locks.
[11/11/2016 07:32:06 AM] filelock-mgr.c(915): Cleaning expired file locks.
[11/11/2016 08:32:06 AM] filelock-mgr.c(915): Cleaning expired file locks.
[11/11/2016 08:56:53 AM] ../common/obj-backend-fs.c(240): [obj backend] Failed to open tmp file /nfs/seafile-data/storage/commits/132fafb7-6fc3-4252-aaf1-29027bae0ac4/1e/ceee1d599718d2f454f7c85dbb867f0b44082f.2EKNQY: Permission denied.
[11/11/2016 08:56:53 AM] ../common/obj-backend-fs.c(322): [obj backend] Failed to write obj 132fafb7-6fc3-4252-aaf1-29027bae0ac4:1eceee1d599718d2f454f7c85dbb867f0b44082f.
[11/11/2016 08:56:53 AM] repo-op.c(474): Failed to add commit.
[11/11/2016 08:57:07 AM] ../common/obj-backend-fs.c(240): [obj backend] Failed to open tmp file /nfs/seafile-data/storage/commits/132fafb7-6fc3-4252-aaf1-29027bae0ac4/fd/6d5a831f7367a3b88d28494d3bf96b70195b44.HSK5QY: Permission denied.
[11/11/2016 08:57:07 AM] ../common/obj-backend-fs.c(322): [obj backend] Failed to write obj 132fafb7-6fc3-4252-aaf1-29027bae0ac4:fd6d5a831f7367a3b88d28494d3bf96b70195b44.
[11/11/2016 08:57:07 AM] repo-op.c(474): Failed to add commit.
[11/11/2016 09:32:06 AM] filelock-mgr.c(915): Cleaning expired file locks.
[11/11/2016 10:32:06 AM] filelock-mgr.c(915): Cleaning expired file locks.
[11/11/2016 11:32:06 AM] filelock-mgr.c(915): Cleaning expired file locks.
[11/11/2016 12:32:06 PM] filelock-mgr.c(915): Cleaning expired file locks.
[11/11/2016 01:32:06 PM] filelock-mgr.c(915): Cleaning expired file locks.
[11/11/2016 02:32:06 PM] filelock-mgr.c(915): Cleaning expired file locks.
[11/11/2016 03:32:06 PM] filelock-mgr.c(915): Cleaning expired file locks.
[11/11/2016 04:32:06 PM] filelock-mgr.c(915): Cleaning expired file locks.
[11/11/2016 05:32:06 PM] filelock-mgr.c(915): Cleaning expired file locks.
[11/11/2016 06:32:06 PM] filelock-mgr.c(915): Cleaning expired file locks.
[11/11/2016 07:32:06 PM] filelock-mgr.c(915): Cleaning expired file locks.
[11/11/2016 08:32:06 PM] filelock-mgr.c(915): Cleaning expired file locks.
[11/11/2016 09:32:06 PM] filelock-mgr.c(915): Cleaning expired file locks.
[11/11/2016 10:32:06 PM] filelock-mgr.c(915): Cleaning expired file locks.
Looks like a permission issue on the data folder. I send a chown command and it’s now working (both Web and Sync Client).
Thanks,
Regards
Strangely, PDF files do not display in the browser. I don’t know if it’s related
This was a permission issuee on /tmp/seafile-office-output. Works fine now
But i still have these kind of errors
ccnet.log
[11/11/16 23:22:11] ../common/peer.c(950): Local peer down
[11/11/16 23:22:11] ../common/peer.c(948): libevent got an error! what=33, errno=104 (Connection reset by peer)
controller.log
[11/11/16 23:24:00] seafile-controller.c(87): spawn_process: /usr/bin/python2.7 -m seafevents.main --config-file /home/cc/seafile/conf/seafevents.conf --loglevel debug --logfile /home/cc/seafile/logs/seafevents.log -P /home/cc/seafile/pids/seafevents.pid
[11/11/16 23:24:00] seafile-controller.c(102): spawned /usr/bin/python2.7, pid 12171
[11/11/16 23:24:10] seafile-controller.c(575): pid file /home/cc/seafile/pids/seafevents.pid does not exist
[11/11/16 23:24:10] seafile-controller.c(600): seafevents need restart...
seahub_django_request.log
2016-11-11 19:39:48,801 [WARNING] django.request:170 get_response Not Found: /services/MyICOffice/
cc@cchum-epcc-seafile-dev:~/seafile/logs$ tail -100 seahub_django_request.log
2016-10-05 00:25:26,170 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-05 06:23:46,000 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-05 06:23:46,417 [WARNING] django.request:170 get_response Not Found: /favicon.ico
2016-10-05 16:42:12,839 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-05 16:42:12,937 [WARNING] django.request:170 get_response Not Found: /favicon.ico
2016-10-05 17:08:10,070 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-05 18:23:54,176 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-05 20:12:15,960 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-05 20:12:16,106 [WARNING] django.request:170 get_response Not Found: /favicon.ico
2016-10-05 20:43:53,250 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-05 20:43:53,358 [WARNING] django.request:170 get_response Not Found: /favicon.ico
2016-10-05 20:43:53,429 [WARNING] django.request:170 get_response Not Found: /favicon.ico
2016-10-05 20:47:47,672 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-05 20:49:06,551 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-05 21:54:26,246 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-05 21:54:26,352 [WARNING] django.request:170 get_response Not Found: /favicon.ico
2016-10-05 21:58:31,457 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-05 22:14:03,819 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-05 22:14:03,930 [WARNING] django.request:170 get_response Not Found: /favicon.ico
2016-10-05 22:14:04,002 [WARNING] django.request:170 get_response Not Found: /favicon.ico
2016-10-05 22:45:52,319 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-05 23:01:17,830 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-05 23:12:37,524 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-05 23:15:50,086 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-05 23:20:37,294 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-05 23:33:05,695 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-05 23:33:50,153 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-05 23:37:13,585 [WARNING] django.request:170 get_response Not Found: /shibboleth
2016-10-05 23:45:23,426 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-05 23:45:28,945 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-05 23:45:29,043 [WARNING] django.request:170 get_response Not Found: /favicon.ico
2016-10-05 23:47:39,768 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-05 23:47:44,673 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-05 23:48:30,185 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-05 23:57:48,518 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-05 23:59:09,172 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-06 11:25:41,904 [WARNING] django.request:170 get_response Not Found: /HNAP1/
2016-10-06 15:40:37,519 [WARNING] django.request:170 get_response Not Found: /favicon.ico
2016-10-06 16:44:53,660 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-06 16:47:48,107 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-06 16:59:13,310 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-06 17:02:27,236 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-06 17:09:05,663 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-06 17:28:34,594 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-06 17:39:40,125 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-06 17:44:39,769 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-06 17:45:12,206 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-06 17:53:34,547 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-06 18:12:23,016 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-06 18:23:44,533 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-06 18:32:05,934 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-06 19:13:23,277 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-06 19:40:04,927 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-06 19:40:15,526 [WARNING] django.request:170 get_response Not Found: /shibboleth-sp/main.css
2016-10-08 18:07:12,857 [WARNING] django.request:170 get_response Not Found: /a2billing/customer/iridium_threed.php
2016-10-08 20:17:08,181 [WARNING] django.request:170 get_response Not Found: /admin/common/graph_pie.php
2016-10-09 21:20:23,919 [WARNING] django.request:170 get_response Not Found: /HNAP1/
2016-10-11 17:01:57,689 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2016-10-12 19:21:21,483 [WARNING] django.request:170 get_response Not Found: /HNAP1/
2016-10-18 22:38:40,603 [WARNING] django.request:170 get_response Not Found: /HNAP1/
2016-10-19 19:10:45,612 [WARNING] django.request:170 get_response Not Found: /HNAP1/
2016-10-21 22:35:29,312 [WARNING] django.request:170 get_response Not Found: /OA_HTML/OA.jsp
2016-10-24 00:05:52,075 [WARNING] django.request:170 get_response Not Found: /HNAP1/
2016-10-27 09:28:58,819 [WARNING] django.request:170 get_response Not Found: /HNAP1/
2016-10-31 00:28:14,249 [WARNING] django.request:170 get_response Not Found: /phpmyadmin/scripts/setup.php
2016-10-31 17:52:43,105 [WARNING] django.request:170 get_response Not Found: /HNAP1/
2016-11-03 06:23:39,035 [WARNING] django.request:170 get_response Not Found: /index.php
2016-11-03 06:23:40,436 [WARNING] django.request:170 get_response Not Found: /admin/images/tango.png
2016-11-05 14:58:11,868 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2016-11-08 02:55:29,145 [WARNING] django.request:170 get_response Not Found: /index.php
2016-11-08 02:55:31,189 [WARNING] django.request:170 get_response Not Found: /admin/images/tango.png
2016-11-10 22:49:01,001 [WARNING] django.request:170 get_response Not Found: /favicon.ico
2016-11-11 00:28:51,069 [ERROR] django.request:256 handle_uncaught_exception Internal Server Error: /ajax/unseen-notices-count/
  File "/home/cc/seafile/seafile-pro-server-6.0.2/seahub/thirdpart/Django-1.8.10-py2.7.egg/django/core/handlers/base.py", line 108, in get_response
  File "/home/cc/seafile/seafile-pro-server-6.0.2/seahub/seahub/auth/middleware.py", line 18, in process_request
    if request.user.is_authenticated() and not request.user.is_active:
  File "/home/cc/seafile/seafile-pro-server-6.0.2/seahub/seahub/auth/middleware.py", line 10, in __get__
    request._cached_user = get_user(request)
  File "/home/cc/seafile/seafile-pro-server-6.0.2/seahub/seahub/auth/__init__.py", line 119, in get_user
    user = backend.get_user(username) or AnonymousUser()
  File "/home/cc/seafile/seafile-pro-server-6.0.2/seahub/thirdpart/shibboleth/backends.py", line 27, in get_user
    user = User.objects.get(email=username)
  File "/home/cc/seafile/seafile-pro-server-6.0.2/seahub/seahub/base/accounts.py", line 85, in get
    emailuser = ccnet_threaded_rpc.get_emailuser(email)
  File "/home/cc/seafile/seafile-pro-server-6.0.2/seafile/lib64/python2.6/site-packages/pysearpc/client.py", line 110, in newfunc
  File "/home/cc/seafile/seafile-pro-server-6.0.2/seafile/lib64/python2.6/site-packages/ccnet/rpc.py", line 71, in call_remote_func_sync
    client = self.pool.get_client()
  File "/home/cc/seafile/seafile-pro-server-6.0.2/seafile/lib64/python2.6/site-packages/ccnet/pool.py", line 29, in get_client
    client = self._create_client()
  File "/home/cc/seafile/seafile-pro-server-6.0.2/seafile/lib64/python2.6/site-packages/ccnet/pool.py", line 21, in _create_client
    client.connect_daemon()
  File "/home/cc/seafile/seafile-pro-server-6.0.2/seafile/lib64/python2.6/site-packages/ccnet/client.py", line 131, in connect_daemon
    return self.connect_daemon_with_pipe()
  File "/home/cc/seafile/seafile-pro-server-6.0.2/seafile/lib64/python2.6/site-packages/ccnet/client.py", line 113, in connect_daemon_with_pipe
    raise NetworkError("Can't connect to daemon")
NetworkError: Can't connect to daemon
Is it normal ?
If you don’t have errors that repeat every a few seconds, it is normal.
I still have errors traced in seahub_django. : this is just for one hour (with few users).
017-11-14 17:49:35,304 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 17:51:10,623 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 17:51:35,881 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 17:53:11,112 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 17:53:36,650 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 17:55:11,790 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 17:55:37,225 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 17:57:12,207 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 17:57:37,828 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 17:59:12,632 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 17:59:38,608 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:01:13,199 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:01:39,187 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:03:13,659 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:03:39,761 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:05:14,095 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:05:40,569 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:07:14,667 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:07:41,149 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:09:15,091 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:09:41,730 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:11:15,525 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:11:42,485 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:13:16,118 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:13:43,077 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:15:16,552 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:15:43,696 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:17:16,979 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:17:44,497 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:19:17,629 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:19:45,072 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:21:18,087 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:21:45,643 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:23:18,519 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:23:46,455 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:25:19,117 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:25:47,039 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:27:19,562 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:27:47,601 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:29:19,987 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:29:48,376 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:31:20,563 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:31:48,996 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:33:20,992 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:33:49,620 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:35:21,438 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:35:50,416 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:37:22,029 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:37:51,011 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:39:22,502 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:39:51,622 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:41:22,972 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:41:52,454 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:43:23,567 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:43:53,046 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:44:01,510 [WARNING] django.request:170 get_response Not Found: /favicon.ico
2017-11-14 18:44:01,519 [WARNING] django.request:170 get_response Not Found: /favicon.ico
2017-11-14 18:45:24,060 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
2017-11-14 18:45:53,679 [WARNING] django.request:98 _reject Forbidden (Referer checking failed - no Referer.): /
I suppose it is not normal…
I’m now on 6.18 pro
Regards
Don’t know about the rest of the log but this line is not a issue.
This is not a issue either:
It can be in this way: A attacker or some person are trying to access / folder in your apache2 or NGINX server and as you don’t have Seafile there it’s writing out that line.
