Feature request: Auto-delete users inactive for X months?
Dear Seafile devs,
would you add a feature which allows Server admins to auto delete users who are inactive for more than X months?
As always: thank you for Seafile CE!
Yes please! (cc @scheff )
If implemented this needs to be done very careful.
Currently there is a last login column in the user table but it says almost nothing. I’ve got an account that is being used for an automated task (thus API only), a few times a week and Seahub says last login in January. The same most likely also applies when using the client. And after logging in on Seahub for 7 days it also looks like you would be inactive while you’re logged in and are actually using the service.
