Hello all,
I allready read the entire forum, but still no luck.
I was looking for a new sync solution and seafile looks like it can do the job
Unfortunately I cannot get it to work.
I made a fresh Ubuntu 16 install. After this I followed the Tutorial . but no luck.
Nginx is working, because if I run my url, it shows me the default nginx page.
But no redirect of what so ever. If I run url:8000 I receive connection refused.
The firewall is open:
To Action From
8000/tcp ALLOW Anywhere
8082/tcp ALLOW Anywhere
443/tcp ALLOW Anywhere
8001 DENY Anywhere
80 ALLOW Anywhere
22 ALLOW Anywhere
8000/tcp (v6) ALLOW Anywhere (v6)
8082/tcp (v6) ALLOW Anywhere (v6)
443/tcp (v6) ALLOW Anywhere (v6)
8001 (v6) DENY Anywhere (v6)
80 (v6) ALLOW Anywhere (v6)
22 (v6) ALLOW Anywhere (v6)
netstat -plntu show that the server is listening
indent preformatted text by 4 spaces
tcp 0 0 127.0.0.1:8000 0.0.0.0:* LISTEN 3784/python2.7
tcp 0 0 127.0.0.1:8080 0.0.0.0:* LISTEN 3306/python2.7
tcp 0 0 0.0.0.0:8082 0.0.0.0:* LISTEN 3307/seaf-server
listen 80;
server_name url
# Reverse proxy for seafile
fastcgi_pass 127.0.0.1:8000;
fastcgi_read_timeout 36000;
# Reverse Proxy for seahub
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
proxy_send_timeout 36000s;
#CHANGE THIS PATH WITH YOUR OWN DIRECTORY
root /home/seafile/seafile-server/seahub;
CCNET.conf
[General]
USER_NAME = xxxxxx
ID = beb98722bcecesb573d8sdfb15ce6f9fbsdfasdas554a6edd499
NAME = ccvitaalsync
SERVICE_URL = url:8000
[Client]
PORT = 13419
I hope someone can help me out.
