Raspberry Pi fails at compiling with this error:
Does anyone know where to get Seafile client (terminal is good enough) for Raspberry Pi?
Short Answer: Yes
Details: Use the search https://forum.seafile.com/search?q=seafile%20client%20raspberry
You can also install it with apt from the debian backports.
You’re right. Thanks.
The backports don’t work. They give some ccnet error that Seafile needs to be installed.
There is also a thread for this.
