Having a phpmyadmin on the same domain with seafile?
I’m trying to resolve an issue I’m having with accessing phpmyadmin.
When i try to access the phpmyadmin I get //domain/phpmyadmin/ I get:
Sorry, but the requested page could not be found.
That has probably something to do with mod_rewrite in apache configuration file but I don’t know how to reconfigure it.
Thanks in advance.
Best regards.
do you really need Apache? If you give a nginx a chance I can send you my configuration where both work together. This should be possible with Apache as well. Maybe another user in Forum has these both.
Thanks for your reply. Im currently set on Apache. I have it on all of our servers.
Thanks again.
You can do this easy in your vhost-config.
There is already a Redirect-exclusion for “your.domain/media”:
RewriteRule ^/(media.*)$ /$1 [QSA,L,PT]
So you have to copy this line and edit i for your specific problem:
RewriteRule ^/(phpmyadmin.*)$ /$1 [QSA,L,PT]
If the Location of phpmyadmin is not in the seafile-folder, then you can make a alias. There is also already one for /media:
Alias /media /home/seafile/haiwen/seafile-server-latest/seahub/media
This can be copied, for example:
 Alias /phpmyadmin /var/www/phpmyadmin
     <Directory "/var/www/phpmyadmin">
          Options -Indexes +FollowSymLinks
          AllowOverride All
          Require all granted
     </Directory>
best regards,
Markus
Thanks a lot :slight_smile:
what’s your config file for nginx and phpmyadmin?
