Help changing servier ip address
I’ve had to change my Seafile server’s static ip address, but I’m having issues (Debian 11). Does anyone know of a resource that explains how to do it? I have been struggling: the services come up, but doing a “ping” on the server name (myseafileserver.com) from the client always brings up the old IP!
Which is why I can’t connect to the server with the new address, Thanks.
As I understand this has nothing to do with Seafile, the change has to be made at domain level.
Search something like edit A record <your registrar>.
As example, here’s the procedure for GoDaddy: https://www.godaddy.com/help/edit-an-a-record-19239
You were correct. It seems that my ISP took its time to make the change!
