Help configuring apache virtual host for Seafile
I installed Seafile on Ubuntu 16.04 for personal home use. I followed this guide and everything works smoothly. However, I need help properly configuring the Apache virtual host for HTTP and HTTPS.
I do NOT have a domain name, so I will always access Seafile server using IP of the server. What I want is to be able to access Seafile by going to http://192.168.1.xxx/seafile.
I followed the guide, Config Seahub with Apache, however, the virtual host configuration causes the Seafile interface to show up whenever I go to http://192.168.1.xxx/. I only want Seafile interface to show up when I go to http://192.168.1.xxx/seafile.
Below is the exact configuration I am using. Note how I have commented out “ServerName”. This reason for this is because if my router changes the IP of the server, I don’t have to come back and update the virtual host file.
<VirtualHost *:80>
    # ServerName www.myseafile.com
    # Use "DocumentRoot /var/www/html" for Centos/Fedora
    # Use "DocumentRoot /var/www" for Ubuntu/Debian
    Alias /media  /home/user/haiwen/seafile-server-latest/seahub/media
    RewriteEngine On
    <Location /media>
        Require all granted
    </Location>
    # seafile fileserver
    # seahub
</VirtualHost>
Also I have one more question. Do I always have to change the SERVICE_URL and FILE_SERVER_ROOT settings if the IP address of the server changes? For example a scenario when the server IP address is 192.168.1.125, but later it may get changed to “192.168.1.132”.
