Problem: Seafile published library not showing homepage content (home.md).
Published library (you can test it out via this link): https://cloud.erbanku.com/published/public-library
It’s a very odd issue I have ever encountered in Seafile.
Can anyone help? Any help is appreciated; thanks.
Seafile version: Seafile Pro Server 9.0.13
OS: Ubuntu 22.04 LTS
Your problem description is wrong. A better problem description is: Seafile published library not showing the first page called, e.g.
https://cloud.erbanku.com/published/public-library/2023/test.md
https://cloud.erbanku.com/published/public-library/home.md
So my guess is that your custom css and/or Cloudflare scripts are somehow broken.
Thanks for your reply.
(BTW, I have changed the library content after posting the problem.)
According to your reply, I have disabled Cloudflare for my site and removed custom CSS in admin settings, but the problem remains.
The problem:
(And the page content can be loaded after do the following)
This seems to be a bug. I can reproduce the problem on my test seafile instance running Seafile Pro 9.0.14 on a Ubuntu 20.04.5 machine.
The firefox network analyzer reports a call to
/api/v2.1/wikis/$LIBRARY/dir/?p=%2F&with_parents=true
on the first call and then
/api/v2.1/wikis/$LIBRARY/content/?p=$PAGE&_=$ID
on subsequent page calls.
@daniel.pan FYI
Okay then, I opened an issue on GitHub. Wait for a fix. Thanks~
My school also uses Seafile (v8.0.17), which is normal. It seems that this issue exists in higher versions.
I can’t reproduce the issue with 9.0.14 pro edition:
The first page is rendered server side for SEO reason. So there is no API call like /api/v2.1/wikis/$LIBRARY/content/?p=$PAGE&_=$ID
This problem exists in Seafile Pro 9.0.13
After upgrading to Seafile Pro 9.0.14
, the problem disappeared.
BTW, Thanks to all~
